楼主: sammy
[源码] 图形复制并对齐【已修正】
发表于 2024-5-21 12:53:35 | 显示全部楼层
;简单的对复制并对齐
(defun c:tt (/ ss p1 p2 p3 p4)
    (command "_.undo" "be")
(if(setq ss (ssget ""))
(setq p1 (getpoint "\n选择基点1: ")
      p2 (getpoint p1 "\n选择基点2: "))
  (command ".copy"  ss "" "non"p1 "non"p1)
  (setq p3 (getpoint "\n目标基点1: ")
        p4 (getpoint p3 "\n目标基点2: "))
(command "_.ALIGN" ss "" "non"p1 "non"p3  "non"p2 "non"p4 "" "" )
      (command "_.undo" "_e")
简单实用!  发表于 2024-5-21 19:12
发表于 2024-5-22 06:27:43 | 显示全部楼层
kwok 发表于 2024-5-21 12:53
;简单的对复制并对齐
闪退
_.undo 当前设置: 自动 = 开,控制 = 全部,合并 = 是,图层 = 是
输入要放弃的操作数目或 [自动(A)/控制(C)/开始(BE)/结束(E)/标记(M)/后退(B)] <1>: be
命令: ; 错误: 参数太少
发表于 2024-5-24 10:46:27 | 显示全部楼层
moranyuyan 发表于 2024-5-22 06:27
闪退
输入要放弃的操作数目或 [自动( ...
把这一句(if(setq ss (ssget ""))
改为(if(setq ss (ssget))就好了
发表于 2024-5-24 15:53:32 | 显示全部楼层
谢谢解答,效果棒极了
GMT+8, 2026-1-14 05:41 , Processed in 0.144756 second(s), 21 queries , Gzip On.
