楼主: hn10183051
[提问] (求助)如何把特殊表中重复删除保留一个
发表于 2024-6-17 20:04:16 | 显示全部楼层
(foreach abc PointList
  (setq px (cadr abc))
  (or (equal
        (car
          (vl-sort (mapcar (function (lambda (x) (distance x px))) Check)
        0.
        0.001
      (setq Check (cons px Check)
            rtn          (cons abc rtn)
(reverse rtn)
发表于 2024-6-18 08:01:04 | 显示全部楼层
几何意义是不是这样, 在直线选择集中,选择有一个节点重合的直线,如果其方向不一致,则删除其中的一条,其他直线不管
 楼主| 发表于 2024-6-18 08:04:07 | 显示全部楼层
  (or (equal
谢谢大佬,可以了
发表于 2024-6-19 07:35:30 | 显示全部楼层
  1. (defun DelSame (lst / tmp lst1)
  2.   "端点重合消除"
  3.   (foreach a lst
  4.     (if (and (not (member (car a) tmp1))(not (member (cadr a) tmp2)))
  5.       (setq tmp1 (cons (car a) tmp1)
  6.             tmp2 (cons (cadr a) tmp2)
  7.             lst1 (cons a lst1)
  8.       )
  9.     )
  10.   )
  11.   (reverse lst1)
  12. )
GMT+8, 2026-1-14 02:41 , Processed in 0.182701 second(s), 20 queries , Gzip On.
