楼主: `中微子
[讨论] 遇到个问题望大神指教,怎么判断一点在角内还是在角外?
发表于 2024-6-24 16:54:06 | 显示全部楼层
总算看懂你在问什么了.你这里不是Point,而是Vector.
判断v4是否在两个向量中间夹着的范围.
应该是点积啊,怎么会是叉积呢.
https://www.cnblogs.com/JJBox/p/14300098.html#_label1
求得v2->v4落在向量a,向量b,同时大于0,就是夹角范围内了.
如果同时小于0,就是蝴蝶状.
谢谢!请看12楼.  发表于 2024-6-25 01:21
 楼主| 发表于 2024-6-25 01:20:07 | 显示全部楼层
这是我的思路,测试成功了,很庞大.有大佬简化一下吗?
(defun c:tt  (/ p1 p2 p4 pt a b mid pa pb)
    ;;三点夹角(来自大佬xyp1964)
    (defun included_angle  (p1 pt p3 / ang)
        (setq ang (- (angle pt p3) (angle pt p1)))
        (if (< ang 0)
            (setq ang (+ (* 2.0 pi) ang)))
        (if (> ang pi)
            (setq ang (- (* 2.0 pi) ang)))
        ang
;;;取二点的中点
    (defun lt:midpoint (p1 p2) (mapcar '(lambda (x y) (/ (+ x y) 2.0)) p1 p2))
;;;主程序
    (setq p1  (getpoint "\n指定线上点1:")
          pt (getpoint p1 "\n指定角点:")
          p2  (getpoint pt "\n指定线上点2:")
          p4  (getpoint "\n指定活动点:")
          pa (polar pt (angle pt p1) 100)
          pb (polar pt (angle pt p2) 100)
          a   (/ (included_angle p1 pt p2) 2)
          mid  (lt:midpoint pa pb)
          b   (included_angle mid pt p4))
    (cond
        ((equal b a 0.001) (princ "\n活动点在线上!"))
        ((> b a) (princ "\n活动点在角外!"))
        ((< b a) (princ "\n活动点在角内!"))
发表于 2024-6-25 01:31:35 | 显示全部楼层
没有点积快
GMT+8, 2026-1-14 02:39 , Processed in 0.156652 second(s), 21 queries , Gzip On.
