楼主: 惜惜2
[提问] 求个大佬帮忙看下红色处的代码,研究找不到原因
发表于 2024-10-13 14:22:26 | 显示全部楼层
惜惜2 发表于 2024-10-10 10:19
ljpnb 发表于 2024-10-7 17:34
是的,先取值
平时很少用到属性块,也学习了一下
(setq e3-length (length E3))这时的length不对,应该是(setq e3-length (strlen E3))
(setq E4 (strcat (substr E3 0 4) "-" (substr E3 4 2) "-" (substr E3 6 2)))中的(substr E3 0 4)应该是(substr E3 1 4),从1开始
 楼主| 发表于 2024-10-14 17:05:30 | 显示全部楼层
(setq E4 (strc ...
感谢
发表于 2024-10-14 21:52:24 | 显示全部楼层
  1. (defun c:tt ()
  2.   (setq dn (vl-filename-base (getvar "dwgname")))
  3.   (if (setq nn (vl-string-search " " dn))
  4.     (progn
  5.       (setq aa (substr dn 1 nn))
  6.       (setq bb (substr dn (+ nn 2)))
  7.       (setq ss (ssget "x" '((0 . "INSERT") (66 . 1))))
  8.       (repeat (setq n (sslength ss))
  9.         (setq s1 (ssname ss (setq n (1- n))))
  10.         (foreach a (reverse (xyp-Att2list s1))
  11.           (setq ts (cadr a)
  12.                 b  (car a)
  13.           )
  14.           (cond ((= ts "客户图号") (xyp-SubUpd b 1 aa))
  15.                 ((= ts "零件名称") (xyp-SubUpd b 1 bb))
  16.                 ((= ts "设计日期") (xyp-SubUpd b 1 (menucmd "m=$(edtime,$(getvar,DATE),yyyy-mo-dd)")))
  17.                 ((= ts "产品编码") (setq e1 (last a)))
  18.                 ((= ts "客户") (xyp-SubUpd b 1 (substr E1 2 3)))
  19.           )
  20.         )
  21.       )
  22.     )
  23.   )
  24.   (princ)
  25. )
 楼主| 发表于 2024-10-15 09:02:19 | 显示全部楼层
感谢版主大大更新的方法
GMT+8, 2026-1-13 12:56 , Processed in 0.239108 second(s), 20 queries , Gzip On.
