楼主: 飞雪神光
万花尺
 楼主| 发表于 2024-12-27 21:29:52 | 显示全部楼层
就是写着玩的...
发表于 2024-12-28 09:47:12 | 显示全部楼层
只是用来玩的吗,还有没有其他用途呢
发表于 2024-12-28 20:28:28 | 显示全部楼层
  1. Private Sub CommandButton2_Click()
  2.     Dim i As Long
  3.     Dim n As Integer
  4.     Dim Pi As Double
  5.     Pi = 4# * Atn(1#)
  6.     Dim R As Long
  7.     Randomize
  8.     R = Int(Rnd * 100)
  9.     Dim R1 As Long
  10.     R1 = (0.5 - Rnd) * 199
  11.     Dim L As Long
  12.     L = Int(Rnd * 200)
  13.     Dim S As Long
  14.     S = Int(Rnd * 50)
  15.     Dim M As Long
  16.     M = Int(Rnd * 100)
  17.     Dim A1 As Double
  18.     Dim A2 As Double
  19.     Dim P(2) As Double
  20.     Dim P0(2) As Double
  21.     Dim x As Double
  22.     Dim y As Double
  23.
  24.     Dim Fit() As Double
  25.     Dim Sp As AcadSpline
  26.
  27.     ReDim Fit(2)
  28.
  29.     i = i + 1
  30.     n = n + 1
  31.     A1 = i * Pi / 180
  32.     A2 = (R1 / R) * A1
  33.
  34.     x = (-(R1 - R) * Cos(A1) - S * Cos(A2 - A1) + 100) * M
  35.     y = ((R1 - R) * Sin(A1) - S * Sin(A2 - A1) + 100) * M
  36.
  37.     P0(0) = x: P0(1) = y
  38.     Fit(0) = x: Fit(1) = y: Fit(2) = 0
  39.
  40.     'ThisDrawing.ModelSpace.AddPoint P0
  41.     Do
  42.         DoEvents
  43.
  44.         i = i + 1
  45.         n = n + 1
  46.         ReDim Preserve Fit(n * 3 - 1)
  47.         A1 = i * Pi / 180
  48.         A2 = (R1 / R) * A1
  49.
  50.         x = (-(R1 - R) * Cos(A1) - S * Cos(A2 - A1) + 100) * M
  51.         y = ((R1 - R) * Sin(A1) - S * Sin(A2 - A1) + 100) * M
  52.         P(0) = x: P(1) = y
  53.         Fit(n * 3 - 3) = x: Fit(n * 3 - 2) = y: Fit(n * 3 - 1) = 0
  54.         If n = 359 Then
  55.             Set Sp = ThisDrawing.ModelSpace.AddSpline(Fit, Point3D(0, 0, 0), Point3D(0, 0, 0))
  56.             Randomize
  57.             'Sp.color = Int(Rnd * 255)
  58.             n = 0
  59.         End If
  60.         If Abs(P(0) - P0(0)) < 10 ^ -2 And Abs(P(1) - P0(1)) < 10 ^ -2 Then Exit Do
  61.         'If i > 10 ^ 4 Then Exit Do
  62.      Loop
  63.      MsgBox "R=" & R & "/ R1=" & R1 & "/ L=" & L
  64.      Prompt "R=" & R & "/ R1=" & R1 & "/ L=" & L & "/ S=" & S & vbCrLf
  65.      End
  66. End Sub
我08年写的一段VBA代码
发表于 2024-12-29 23:27:58 | 显示全部楼层
很特别的玩意,很好的范例!收藏!
发表于 2025-1-2 13:31:48 | 显示全部楼层
v2.0將版主的程式功能再提升一些:
发表于 2025-1-2 13:33:12 | 显示全部楼层
此圖片產生圖形之參數設定值 可供參考
GMT+8, 2026-1-15 13:46 , Processed in 0.146171 second(s), 18 queries , Gzip On.
