查看: 5722|回复: 13
[源码] 面积求和
发表于 2025-1-22 02:07:11 | 显示全部楼层 |阅读模式
;;计算各种表面、面域的面积和。设计 何勇
;;注意:绘图单位以毫米计。
(defun C:calmj(/ ss e ent)
  (setq ss (ssget))
  (setq are1 0)
  (while ss
    (setq
      e (ssname ss 0)
      ent (entget e)
      ss (if (> (sslength ss) 1)
             (ssdel e ss)
          nil
    (cond ((or (=  (cdr (assoc 0 ent))  "LWPOLYLINE")
                           (=  (cdr (assoc 0 ent))  "POLYLINE")
                           (=  (cdr (assoc 0 ent))  "REGION")
                           (=  (cdr (assoc 0 ent))  "LOFTEDSURFACE")
                           (=  (cdr (assoc 0 ent))  "SURFACE")
                           (=  (cdr (assoc 0 ent))  "REVOLVEDSURFACE")
                           (=  (cdr (assoc 0 ent))  "EXTRUDEDSURFACE")
                           (=  (cdr (assoc 0 ent))  "PLANESURFACE")
                           (=  (cdr (assoc 0 ent))  "SWEPTSURFACE")
                 (command "AREA" "e" e)
                   (setq
                         are1 (+ are1 (getvar "AREA"))
        );;end cond
  );;end while
  (princ (strcat "\n总面积为:" (rtos are1) "mm2"))
  (princ (strcat "\n总面积为:" (rtos (/ are1 1000000.0)) "m2"))
  (prin1)
发表于 2025-1-22 09:28:24 | 显示全部楼层
;;    |                 实体面积                 |
;;说明:实体面积
;;参数:entcar (entsel))
;;返回fx-area (car (entsel)))面积
(defun fx-area(ent / obj-vla obj-area)
        (if (and ent (= 'ENAME (type ent)))
                        (setq obj-vla (vlax-ename->vla-object ent))
                        (setq obj-area (vla-get-Area obj-vla))
;;    |              选择集实体面积               |
;;说明:图形面积 m2
;;参数:ss:选择集或图元 (选择集则为面积和)
;;返回fx-txmj (ssget))  (fx-txmj (car (entsel)))
(defun fx-txmj(ss / EN N ssa TOT_AREA)
        (if (and ss (= 'PICKSET (type ss)))
                (setq ss ss)
                (if (and ss (= 'ENAME (type ss)))
                                (setq
                                        ssa nil
                                        ssa (ssadd)
                                        ssa (ssadd ss ssa)
                                        ss ssa
                        (setq n -1)
                        (setq tot_area 0)
                        (repeat (sslength ss)
                                (setq en (vla-get-Area (vlax-ename->vla-object (ssname ss (setq n (1+ n))))))
                                (setq tot_area (+ tot_area en))
                        (setq tot_area (/ tot_area 1000000))
        tot_area
 楼主| 发表于 2025-1-22 19:34:27 | 显示全部楼层
yanshengjiang 发表于 2025-1-22 15:03
前辈你好    这样看起来在ssget的时候就能过滤
;;你说得有道理,根据你的建议将程序修改如下:
;;注意:绘图单位以毫米计。
  (setq SS (ssget '((0 . "SPLINE,circle,ELLIPSE,LWPOLYLINE,POLYLINE,REGION,LOFTEDSURFACE,SURFACE,REVOLVEDSURFACE,EXTRUDEDSURFACE,PLANESURFACE,SWEPTSURFACE"))))
  (setq are1 0)
  (while ss
    (setq
      e (ssname ss 0)
      ent (entget e)
             (ssdel e ss)
          nil
    (setq are1 (+ are1 (getvar "AREA")))
  );;end while
  (prin1)
;;欢迎各位朋友批评指正
发表于 2025-1-22 09:29:55 | 显示全部楼层
  1. (defun c:tt ()
  2.   (if (setq ss (ssget '((0 . "arc,cir*,*line,re*,*surface,ell*"))))
  3.     (progn
  4.       (setq i -1
  5.             a 0
  6.       )
  7.       (while (setq e (ssname ss (setq i (1+ i))))
  8.         (command "AREA" "o" e)
  9.         (setq a (+ a (getvar 'AREA)))
  10.       )
  11.       (princ (strcat "\n总面积为: " (rtos a) " 平方毫米"))
  12.       (princ (strcat "\n总面积为: " (rtos (* a 1e-6)) " 平方米"))
  13.     )
  14.   )
  15.   (princ)
  16. )
发表于 2025-1-22 07:57:03 | 显示全部楼层
似乎alisp只能用(command "AREA" "e" e)求面积,autocad2000之后有了com,用vla-get-area就可以求得面积
发表于 2025-1-22 08:24:34 | 显示全部楼层
谢谢分享谢谢分享谢谢分享
发表于 2025-1-22 09:02:20 | 显示全部楼层
(member (cdr (assoc 0 ent))'("LWPOLYLINE" "POLYLINE""REGION""LOFTEDSURFACE""SURFACE""REVOLVEDSURFACE""EXTRUDEDSURFACE""PLANESURFACE""SWEPTSURFACE"))
发表于 2025-1-22 13:07:19 | 显示全部楼层
好代码,学习了,谢谢
发表于 2025-1-22 14:29:01 | 显示全部楼层
https://www.cnblogs.com/JJBox/p/14300098.html#_lab2_4_4
鞋带公式,直接算,嘻嘻
发表于 2025-1-22 15:03:20 | 显示全部楼层
夏生生 发表于 2025-1-22 09:02
(member (cdr (assoc 0 ent))'("LWPOLYLINE" "OLYLINE""REGION""LOFTEDSURFACE""SURFACE""REVOLVEDSURFACE ...
发表于 2025-1-22 16:24:30 | 显示全部楼层
那确实,只是告诉他有这么个方法
GMT+8, 2026-1-1 08:54 , Processed in 0.195505 second(s), 26 queries , Gzip On.
