查看: 789|回复: 4
o3年编的的程序能否转换成现在高版本的程序
发表于 2025-7-8 08:44:50 | 显示全部楼层 |阅读模式
10明经币
一个是输入法自动转换成英文,比较简单,
一个是型材程序,用到了WTL
二十几年前的了,现在不会编程了
// Includes
#define _AFX_NOFORCE_LIBS // we do not want to link to MFC DLLs or libs
#ifdef _DEBUG
#define WAS_DEBUG
#undef _DEBUG
#endif
#include "afxwin.h"  // need this because ******rxmfcapi.h****** needs windows header.
#ifdef WAS_DEBUG
#undef WAS_DEBUG
#define _DEBUG
#endif
#include "aced.h"
#include "adslib.h"
#include "rxmfcapi.h"
#include "acedads.h"
#include "acdocman.h"
// Standard C Test function
void autoime();                   // ARX callbacks
void mouse();
void unautoime();
void unmouse();
BOOL filterLC(MSG *pMsg);      // hook function for autoimeing.
BOOL filterMouse(MSG *pMsg);   // hook function for making mouse dragging
                               // only horizontal or vertical based on
                               // SHIFT or Control key is pressed or not.
static BOOL vMode; // holds mouse vertical Mode status
static BOOL hMode; // holds mouse horizontal Mode status
// preventing from inserting the same hook twice.
static BOOL autoimeDone = FALSE;
static BOOL mouseDone = FALSE;
// Rx interface
void initApp()
  acedRegCmds->addCommand( "MKEvents",      // Group name
                           "autoime",      // Global function name
                           "autoime",          // Local function name
                           ACRX_CMD_MODAL,    // Type
                           &autoime );         // Function pointer
                           "vhmouse",      // Global function name
                           "vhmouse",          // Local function name
                           &mouse );         // Function pointer
                           "unautoime",      // Global function name
                           "unautoime",          // Local function name
                           &unautoime );         // Function pointer
                           "unvhmouse",      // Global function name
                           "unvhmouse",          // Local function name
                           &unmouse );         // Function pointer
  //acutPrintf( ".OK!\n" );
void unloadApp()
  // Remove the command group because we are unloading
  acedRegCmds->removeGroup( "MKEvents" );
  // Removing all hooks <no matter they're planted or not>
  if (autoimeDone == TRUE)
      acedRemoveFilterWinMsg(filterLC);
  if (mouseDone == TRUE)
      acedRemoveFilterWinMsg(filterMouse);
// Entry point
extern "C" AcRx::AppRetCode acrxEntryPoint( AcRx::AppMsgCode msg, void* pkt)
  switch( msg )
    case AcRx::kInitAppMsg:
      initApp();
      acrxUnlockApplication(pkt);
          acrxDynamicLinker->registerAppMDIAware(pkt);
          //initialize
      autoime();
      break;
    case AcRx::kUnloadAppMsg:
      unloadApp();
      break;
    default:
      break;
  return AcRx::kRetOK;
        //HWND hCmdLineHWnd =  acedGetAcadTextCmdLine()->m_hWnd;
        if (acDocManager->curDocument() == NULL) return FALSE;
        static struct resbuf rb;
        acedGetVar("CMDACTIVE", &rb);
        static HKL hklCurrent;
    hklCurrent=GetKeyboardLayout(0);
    if (rb.resval.rint == 0 && (int)hklCurrent<0 )
        //acutPrintf("\n%d:%d",hklCurrent,rb.resval.rint);
                ActivateKeyboardLayout(0,KLF_SETFORPROCESS);//激活输入法,注意复制文本时有非法字符 error C2018: 未知字符“0xa1”;不支持 unicode 标识符
    return FALSE; // continue
// Pressing CTRL key when dragging makes the mouse moves vertical only
// Pressing SHIHT key when dragging makes the mouse moves horizontal only
    static long ptx=0;
    static long pty=0;
    if (pMsg->message == WM_MOUSEMOVE || pMsg->message == WM_LBUTTONDOWN
        || pMsg->message == WM_LBUTTONUP)
        if ((pMsg->message == WM_LBUTTONDOWN || pMsg->message == WM_LBUTTONUP) &&
             (vMode == TRUE ||  hMode == TRUE))
            pMsg->lParam = MAKELONG(ptx, pty);
            return FALSE;
        if (pMsg->wParam == MK_CONTROL)
            if (vMode == TRUE) // Prev Pt is set already
                pMsg->lParam = MAKELONG(ptx, HIWORD(pMsg->lParam));
                pty = HIWORD(pMsg->lParam);
            } else
                ptx= LOWORD(pMsg->lParam);
            vMode = TRUE;
            hMode = FALSE;
        } else if (pMsg->wParam == MK_SHIFT)
            if (hMode == TRUE) // Prev Pt is set already
                pMsg->lParam = MAKELONG(LOWORD(pMsg->lParam), pty);
                ptx = LOWORD(pMsg->lParam);
            } else
                pty= HIWORD(pMsg->lParam);
            hMode = TRUE;
            vMode = FALSE;
        } else
            vMode = hMode =  FALSE;
void autoime()
    if (autoimeDone == TRUE) // already has the hook??
      return;
    //acutPrintf( "autoimeing...\n" );
    if (acedRegisterFilterWinMsg(filterLC) == FALSE)
        acutPrintf("Can't register Windows Msg hook - autoime\n");
    else
      autoimeDone = TRUE;
void unautoime()
void mouse()
    if (mouseDone == TRUE) // already has the hook?
      return;
    ::vMode = FALSE;
    ::hMode = FALSE;
    acutPrintf( "mouseing...\n" );
    if (acedRegisterFilterWinMsg(filterMouse) == FALSE)
        acutPrintf("Can't register Windows Msg hook - VH - mouse\n");
    else
        mouseDone = TRUE;
void unmouse()
        mouseDone = FALSE;
附件: 您需要 登录 才可以下载或查看,没有账号?注册
发表于 2025-7-19 19:28:54 | 显示全部楼层
xg.rar 里面缺少文件。
发表于 2025-7-20 12:16:27 | 显示全部楼层
这个输入法钩子函数写的合适吗?看着感觉不太对啊
 楼主| 发表于 2025-8-3 08:38:03 | 显示全部楼层
在autocad2002下没问题
发表于 2025-8-3 08:58:59 | 显示全部楼层
试试 Autoime 能不能用。压缩包里包含已编译的。
这个型钢压缩包里面缺少类文件。
GMT+8, 2026-1-9 04:30 , Processed in 0.163656 second(s), 21 queries , Gzip On.
