- 积分
- 6121
- 明经币
- 个
- 注册时间
- 2022-9-23
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
发表于 2025-9-1 19:36:50
显示全部楼层
(defun c:DWGTools (/)
;; 主功能选择菜单
(initget "Insert Split")
(setq choice (getkword "\n选择功能 [插入(I)/拆分(S)]: <I> "))
(if (not choice) (setq choice "Insert"))
(cond
((= choice "Insert") (c:BatchInsert))
((= choice "Split") (c:BatchSplit))
(defun c:BatchInsert (/ pf path aa n i nn pp)
;; 批量插入功能 - 仅支持块插入
(setvar "CMDECHO" 0)
(setq pf (getfiled "选择要插入的DWG文件" "" "dwg" 8))
(if (not pf) (progn (princ "\n未选择文件。") (exit)))
(setq path (vl-filename-directory pf))
(setq path (strcat path "\\"))
(setq aa (vl-directory-files path "*.dwg" 1))
(setq n (length aa))
(setq i 0 nn 0)
(prompt "\n正在按块插入图幅,请稍候...\n")
(while (< i n)
(setq pp (nth i aa))
(setq fullpath (strcat path pp))
(command "insert" fullpath "0,0" "1" "1" "0")
(setq nn (1+ nn))
(princ (strcat "第" (itoa nn) "个图块: " pp " \r"))
(setq i (1+ i))
(command "zoom" "e" "zoom" "0.8x")
(setvar "CMDECHO" 1)
(princ (strcat "\n操作完成,共处理了 " (itoa nn) " 个文件。"))
(defun c:BatchSplit (/ winshell *avzzts-reg-root* *avzzts-reg-key* path folder root filename name ss ss1 i desktopPath)
;; 批量拆分功能 - 改进版本,默认保存到桌面
(princ "-->图纸拆分导出")
(setvar "cmdecho" 0)
;; 获取桌面路径
(setq desktopPath (strcat (getenv "USERPROFILE") "\\Desktop\\"))
(setq winshell (vlax-create-object "Shell.Application"))
(setq *avzzts-reg-root* "HKEY_CURRENT_USER\\Software\\Autodesk\\avzztls")
(setq *avzzts-reg-key* (strcat *avzzts-reg-root* "\\R" (vl-princ-to-string (atof (getvar "acadver")))))
(setq path (vl-registry-read *avzzts-reg-key* "dwgsplitpath"))
;; 如果注册表中没有路径或路径无效,使用桌面路径
(if (or (null path) (null (findfile path)))
(setq folder (strcat "分图_" (menucmd "M=$(edtime,$(getvar,date),YYYY-MM-DD)")))
(setq path (strcat desktopPath folder))
;; 创建文件夹(如果不存在)
(if (not (vl-file-directory-p path))
(vl-mkdir path)
(setq filename (getfiled "请输入文件名" path "dwg" 1))
;; 如果用户取消了文件选择,退出函数
(if (not filename)
(princ "\n操作已取消。")
(setvar "cmdecho" 1)
(return)
(setq name (vl-filename-base filename))
(setq path (vl-string-right-trim "\\" (vl-filename-directory filename)))
(vl-registry-write *avzzts-reg-key* "dwgsplitpath" path)
(princ "\n请选择需要分图的内容:")
(setq i 0)
(setq ss1 nil)
(while (setq ss (ssget))
(vl-cmdf "wblock"
(strcat path name
"_" (menucmd "M=$(edtime,$(getvar,date),HH-MM-SS)")
"_" (itoa (setq i (1+ i)))
".dwg")
"" "0,0" ss "")
(vl-cmdf "oops")
(princ (strcat "\n已保存: " path name "_" (menucmd "M=$(edtime,$(getvar,date),HH-MM-SS)") "_" (itoa i) ".dwg"))
(princ "\n请继续选择<右键结束>:")
(setq ss1 ss)
(if ss1
(vlax-invoke-method winshell 'open path)
(princ (strcat "\n所有文件已保存到: " path))
;; 提供独立命令别名
(defun c:BI () (c:BatchInsert))
(defun c:BS () (c:BatchSplit))
(princ "\nDWG工具已加载,命令: DWGTools (或 BI/BS 直接调用功能)")
(princ) |
