楼主: WHW
圆弧标注!!11
 楼主| 发表于 2004-6-15 18:25:00 | 显示全部楼层
问题已解决。 以下程序有BDYCASD提供,加载运行就行了! (defun c:yh(/ en pt len_data old_hc l new_hc len_data)
(setq en (entsel "选弧: "))
(setq pt (getpoint "定点: "))
(command "dimangular" en pt)
(setq len_data (entget (entlast)))
(setq old_hc (assoc 1 len_data))
(command "lengthen" (car en) "")
(setq l (getvar "perimeter"))
(setq new_hc (cons 1 (rtos l 2 2)))
(setq len_data (subst new_hc old_hc len_data))
(entmod len_data)
GMT+8, 2026-1-14 12:40 , Processed in 0.132602 second(s), 18 queries , Gzip On.
