楼主: mshuser
江湖救急!
 楼主| 发表于 2004-8-16 22:27:00 | 显示全部楼层
诸位版主及高手: 下列代码我想把用户输入的值加入到文本对象的1000延伸数据中,为什么不可以呢?错在哪里? Sub ShuRu()
Dim xhobj As AcadText
Dim xuahao As Integer
xuahao = ThisDrawing.Utility.GetString(1, vbCrLf & "序号:")
Dim datatype(0 To 1) As Integer
Dim data(0 To 1) As String
datatype(0) = 1001: data(0) = "number"
datatype(1) = 1000: data(1) = "xuhao"
xhobj.SetXData datatype, data
End Sub
发表于 2004-8-17 09:25:00 | 显示全部楼层
帮助的代码没看仔细? Dim Data(0 To 9) As Variant
 楼主| 发表于 2004-8-17 11:11:00 | 显示全部楼层
改过来了,可是总是提示:运行错误91,对象变量或with块变量未设置。另外用insertblock插入在cad中做好的属性块,怎么做呀,做不出来,我按例子做的,如:在cad中作了一个btblock的属性块,在vba中插入: Dim blkRefObj As AcadBlockReference
Dim insertPnt(0 To 2) As Double
insertPnt(0) = 120: insertPnt(1) = 100: insertPnt(2) = 0
Set blkRefObj = ThisDrawing.ModelSpace.InsertBlock(insertPnt, _
"btblock", 1#, 1#, 1#, 0#)
blkRefObj.Update
MsgBox ""
ThisDrawing.Regen True
GMT+8, 2026-1-7 07:26 , Processed in 0.158892 second(s), 17 queries , Gzip On.
