楼主: matichen
请问 LOGAND 的详细用法 (陈老师你那本书也说得太不详细了,就HELP里那两个例子,
发表于 2002-10-12 23:20:00 | 显示全部楼层
还有dim的类型。。。平常可能用得很少,用上了就知道好。
发表于 2002-10-13 08:47:00 | 显示全部楼层
因为不光是1满足:
70 Polyline flag (bit-coded); default is 0:
1 = This is a closed polyline (or a polygon mesh closed in the M direction)
2 = Curve-fit vertices have been added
4 = Spline-fit vertices have been added
8 = This is a 3D polyline
16 = This is a 3D polygon mesh
32 = The polygon mesh is closed in the N direction
64 = The polyline is a polyface mesh
128 = The linetype pattern is generated continuously around the vertices of this polyline
比如,1+8=9
即二进制  0001 + 1000 = 1001
如果碰到一条polyline, 它是(70 . 9)的,
那么,根据9的二进制为1001, 它的右边第一位是1,说明它是闭合的。
又根据从右边数第4位也是1,说明这同时还是一条3dpoly
如何判断右边第一位是1呢,用 0001与它做逻辑与运算,
即 0001 and 1001 = 0001
所以,(logand 1 (cdr (assoc 70 ent)))即可判断右边第一位是不是1
同理,用 1000 (十进制即为8)与它做与运算,可以判断它是不是3dpoly
即 (logand 8 (cdr (assoc 70 ent)))
如果直接判断是不是为1,当然会漏掉好过种可能,你将不能正确判断闭合的3dpoly, 闭合的但fit过的polyline, 闭合的3dmesh等等。判断就不准确。
发表于 2011-6-16 15:47:21 | 显示全部楼层
学习了,但还不是很明白
(loagand 7 15 3)            返回              3
怎么理解?
发表于 2011-6-16 16:36:40 | 显示全部楼层
我收藏有这么一个例子
(if (= (logand (cdr (assoc 70 (tblsearch "LAYER" "dim"))) 1) 1)
        (command "_.layer" "thaw" "dim" "")
        (command "_.layer" "freeze" "dim" "")
只要冻结状态才解冻,其它状态都将冻结;
发表于 2011-6-16 16:50:02 | 显示全部楼层
发表于 2013-5-9 17:32:31 | 显示全部楼层
这两个函数平时不怎用到,也弄不太明白,今天终于了解了一些,不错.
发表于 2019-10-31 09:19:05 | 显示全部楼层
谢谢各位大神分享
发表于 2020-1-16 00:13:15 | 显示全部楼层
一言惊醒梦中人!!!
GMT+8, 2026-1-17 10:10 , Processed in 0.158843 second(s), 18 queries , Gzip On.
