查看: 3640|回复: 5
如何在vlisp实现Qleader->Setting->Annotation->None?
发表于 2002-10-15 11:28:00 | 显示全部楼层 |阅读模式
如何用vlisp实现Qleader->Setting->Annotation->None?
发表于 2002-10-16 11:09:00 | 显示全部楼层
I suffered this problem for such a long time...
there must be a variable to control this, but I can't find it. So I write another routine to replace it although it is not as good as the original one.
 楼主| 发表于 2002-10-17 05:33:00 | 显示全部楼层
use following vlisp code: (command "leader" pt1 pt2 "" "" "n")
发表于 2002-10-17 08:24:00 | 显示全部楼层
Myleader.lsp
if the number of points you request are more than 3, you have to modified the code.
发表于 2002-10-17 08:41:00 | 显示全部楼层
Sorry, that's rubbish, it can be so simple...
(Defun CD(/ p1 p2 p3)
         (setq ortho (getvar "ORTHOMODE"))
         (setvar "ORTHOMODE" 0)
         (setq p1 (getpoint "\nFirst Point:"))
         (setq p2 (getpoint p1 "\nSecond Point: "))
         (grdraw p1 p2 7)
         (setvar "ORTHOMODE" 1)
         (setq p3 (getpoint p2 "\nNext Point: "))
           (cond ((/= p3 nil)
                 (VL-CmdF "leader" p1 p2 p3 "" "" "n"))
               ((= p3 nil)
                (VL-CmdF "leader" p1 p2 "" "" "n"))
           );cond
         (VL-CmdF "redraw")
        (setvar "ORTHOMODE" ortho)
发表于 2002-10-18 08:48:00 | 显示全部楼层
It is better now...
(defun C:MLD()
  (command "leader" pause pause pause "" "" "n"); for 3 points
GMT+8, 2026-1-2 07:24 , Processed in 0.153517 second(s), 25 queries , Gzip On.
