楼主: changch
非常感谢关注本贴的所有朋友,向meflying献花致谢!!!
 楼主| 发表于 2004-10-29 10:57:00 | 显示全部楼层
我怕我的贴了会沉下去呀???
我知道这里有这个实力的!!!
发表于 2004-10-29 12:10:00 | 显示全部楼层
这里数你最急,有精力在这里催促,何不动脑筋自己好毫安好想想?
  1. (defun DrawLine(pt1 pt2 / ang)
  2.    (setq ang (angle pt1 pt2))
  3.    (command "_.line" pt1 (polar pt1 ang 6.0) "")
  4.    (command "_.line" (polar pt2 (- ang pi) 6.0) pt2 "")
  5. )
  6. (defun c:PQ( / i pt1 pts pt3 ang1 ang2 ang3 ang)
  7.    (setq i 1)
  8.    (setvar "cmdecho" 0)
  9.    (while (or (< i 3) pt1)
  10.        (if (> i 1)
  11.            (progn
  12.   (setq pt1 (getpoint pt1 (strcat "\n请输入第" (itoa i)"点:")))
  13.   (command pt1)
  14.            )
  15.            (progn
  16.   (setq pt1 (getpoint (strcat "\n请输入第" (itoa i)"点:")))
  17.   (command "_.pline" pt1 "w" 0 0)
  18.            )
  19.        )
  20.        (if pt1
  21.            (setq pts (append pts (list pt1)))
  22.        )
  23.        (setq i (1+ i))
  24.    )
  25.    (setq pt3 (getpoint "\n请确定箭头方向:"))
  26.    (entdel (entlast))
  27.    (setq ang1 (angle (car pts) pt3))
  28.    (setq ang2 (angle (car pts) (cadr pts)))
  29.    (setq ang (- ang1 ang2))
  30.    (if (> ang pi) (setq ang (- ang (* 2 pi))))
  31.    (if (< ang (- pi)) (setq ang (+ ang (* 2 pi))))
  32.    (if (> ang 0)
  33.        (setq ang (+ ang2 (* 0.5 pi)))
  34.        (setq ang (- ang2 (* 0.5 pi)))
  35.    )
  36.    (setq pts (reverse pts))
  37.    (setq ang1 (angle (car pts) pt3))
  38.    (setq ang2 (angle (car pts) (cadr pts)))
  39.    (setq ang1 (- ang1 ang2))
  40.    (if (> ang1 pi) (setq ang1 (- ang1 (* 2 pi))))
  41.    (if (< ang1 (- pi)) (setq ang1 (+ ang1 (* 2 pi))))
  42.    (if (> ang1 0)
  43.        (setq ang2 (+ ang2 (* 0.5 pi)))
  44.        (setq ang2 (- ang2 (* 0.5 pi)))
  45.    )
  46.    (setvar "osmode" 0)
  47.    (command "layer" "s" "dim" "")
  48.    (mapcar 'DrawLine (reverse (cdr pts)) (cdr (reverse pts)))
  49.    (command "_.pline" (polar (car pts) ang2 2.5) "w" "1.2" "0" (polar (car pts) ang2 6) "")
  50.    (command "_.pline" (polar (car (reverse pts)) ang 2.5) "w" "1.2" "0" (polar (car (reverse pts)) ang 6) "")
  51.    (command "layer" "s" "thick-solid" "")
  52.    (command "_.line" (car pts) (polar (car pts) ang2 2.5) "")
  53.    (command "_.line" (car (reverse pts)) (polar (car (reverse pts)) ang 2.5) "")
  54.    (setvar "osmode" 33)
  55.    (princ "\n END.")
  56.    (setvar "cmdecho" 1)
  57.    )
发表于 2004-10-29 12:45:00 | 显示全部楼层
嘿嘿,大家各有各的事情,编程只是业余爱好
 楼主| 发表于 2004-10-29 13:01:00 | 显示全部楼层
真的好高兴啊 有那么多的朋友关注过本贴 向meflying版主献花了!!!!!
GMT+8, 2025-12-24 11:40 , Processed in 0.252227 second(s), 19 queries , Gzip On.
