楼主: jordan
阶梯轴绘制
发表于 2004-11-9 14:11:00 | 显示全部楼层
  1. ;;改了一些,可能不是你所希望
  2. (defun C:ZD (/ NUM CNT ST SL N OS D L R PT1 P2 P3 DIST DY SX)
  3.    (while
  4.        (and (setq NUM (getint "\n输入轴的段数或孔的个数<enter退出>: "))
  5.    (setq CNT (getpoint "\n指定轴或孔的中心位置<enter退出>: "))
  6.        )
  7.          (setq ST CNT
  8.        SL 0
  9.          )
  10.          (setq N 1)
  11.          (setq OS (getvar "osmode"))
  12.          (setvar "cmdecho" 0)
  13.          (while (<= N NUM)
  14.              (initget 7)
  15.              (setq
  16.    D (getdist CNT (strcat "\n输入第" (itoa N) "段轴或孔的直径:"))
  17.              )
  18.              (initget 7)
  19.              (setq L
  20.              (getdist CNT
  21.                  (strcat "\n输入第" (itoa N) "段轴的长度或孔的深度:")
  22.              )
  23.              )
  24.              (setq
  25.    R (/ D 2)
  26.              )
  27.              (setq SL  (+ SL L)
  28.            P1  (polar CNT (/ pi 2) R)
  29.            P2  (polar CNT (/ (- pi) 2) R)
  30.            P3  (polar P2 0 L)
  31.              )
  32.              (setvar "osmode" 0)
  33.              (command "_.rectang" P1 P3)
  34.              (setq ANG (angle P1 P3))
  35.              (setq DIST (distance P1 P3))
  36.              (setq DY (abs (* DIST (sin ANG))))
  37.              (setq DX (abs (* DIST (cos ANG))))
  38.              (setq P1 (polar P1 0 DX))  ;平移下一段轴的起点
  39.              (setq CNT (polar CNT 0 DX))  ;平移下一段轴的中心点
  40.              (if (< (cadr P1) (cadr P3))
  41.    (command "move" "L" "" CNT CNT "")
  42.              )
  43.              (setq N (1+ N))
  44.          )
  45.          (if (tblsearch "layer" "3中心线层")
  46.              (command "layer" "s" "3中心线层" "")
  47.              (command  "layer"  "m" "3中心线层"  "l" "center2" "" "C" "1" "" "")
  48.          )
  49.          (command "line"
  50.              (polar ST pi (* SL 0.05))
  51.              (polar ST 0 (+ (* SL 0.05) SL))
  52.              ""
  53.          )
  54.          (command "layer" "s" "0" "")
  55.          (setvar "osmode" OS)
  56.    )
  57.    (alert "阶梯轴或孔绘製结束!")
  58.    (princ)
  59. )
 楼主| 发表于 2004-11-15 21:09:00 | 显示全部楼层
是啊。。好象我是用不到。但对没有天河的人来说却很有用了。。 谢谢龙柯
GMT+8, 2025-12-16 22:30 , Processed in 0.147666 second(s), 20 queries , Gzip On.
