楼主: dwgplt
[求助]请CAD高手帮忙看一下,这个LISP程序为什么在R14下无法用?
 楼主| 发表于 2002-10-21 22:22:00 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
 楼主| 发表于 2002-10-21 22:25:00 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2002-10-22 08:20:00 | 显示全部楼层
程序能把线打断,但因没有阀门图面可供测试!!!!!!!!!
从错误信息看来,是加载程序时出错,你先单独加载程序并执行看看。
因我的错误信息只是:
"fm00.dwg": 搜寻路径内找不到档案:
发表于 2002-10-22 23:40:00 | 显示全部楼层
p2,p3的值不对。
p2,p3的值不对,R14中LWPOLYLINE的实体数据与POLYLINE不一样,顶点坐标格式不一样,你打开实体数据看一下就知道了。
 楼主| 发表于 2002-10-24 20:31:00 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2002-10-25 08:38:00 | 显示全部楼层
好了!!
(defun C:ZF (/ !ZF EN EN1 EM XM ANG LK P1 P2 P3 P4 P5); HOLDPT TMP)
  (setq        KS (getvar "ltscale")
        LK (* 2 KS)
  (setvar "attdia" 0)
  (setvar "cmdecho" 0)
  (setvar "aperture" 3)
  (setvar "pickbox" 3)
  (while (/= !ZF t)
    (princ "\n     ")
    (princ "\n     ")
    (setq EN (entsel "\n选择闸阀插入点:"))
    (initget "Y N")
    (setq XM (getkword "\n画法兰盘吗<Y/N>?"))
    (if        (or (= XM "Y") (= XM "y"))
      (setq LK (* 2.5 KS))
      (setq LK (* 2 KS))
    (if        EN                                ;if1
        (setq EM (entget (car EN)))        ;progn1
        ;;增加一段把LWPOLYLINE转POLYLINE程序
        (if (= (cdr (assoc 0 EM)) "LWPOLYLINE")
            (setq HOLDPT (getvar "LINETYPE"))
            (setvar "LINETYPE" 0)
            (command "_.EXPLODE" (car EN))
            (setq TMP (ssget ""))
            (command "_.PEDIT" (ssname TMP 0) "" "J" TMP "" "")
            (setq EN (nentselp (cadr EN)))
            (setvar "LINETYPE" HOLDPT)
        ;;改用CONVERTPOLY把LWPOLYLINE转POLYLINE程序
            (command "_.CONVERTPOLY" "H" (car EN) "")
        (if (or        (= (cdr (assoc 0 EM)) "OLYLINE") ;if2
                (= (cdr (assoc 0 EM)) "LINE")
          (progn                        ;progn2
            (if        (= (cdr (assoc 0 EM)) "OLYLINE")
                (setq P2 (cdr
                           (assoc 10 (entget (setq EN1 (entnext (car EN)))))
                      P3 (cdr (assoc 10 (entget (entnext EN1))))
                (setq P2 (cdr (assoc 10 (entget (car EN))))
                      P3 (cdr (assoc 11 (entget (car EN))))
            (if        (>= (distance P2 P3) (* 4 KS)) ;if3
              (progn                        ;progn3
                (setq ANG (angle P2 P3)
                      P1  (osnap (cadr EN) "NEAREST")
                      P4  (polar P1 ANG LK)
                      P5  (polar P1 (+ ANG pi) LK)
                      ANG (* ANG (/ 180 pi))
                (command "break" P1 "f" P4 P5)
                (if (= LK (* 2.5 KS))
                  (cond
                    ((and (> ANG 22.5) (< ANG 67.5))
                     (command "insert" "c:/dwg/fm00" P4        KS "" ""
                              "insert" "c:/dwg/fm00" P5        KS "" ""
                    ((and (> ANG 202.5) (< ANG 247.5))
                    (t
                     (command "insert" "c:/dwg/fm00" P4        KS "" ANG
                              "insert" "c:/dwg/fm00" P5        KS "" ANG
                  )                        ;cond end
                (cond
                   (command "insert" "c:dwg/fm02" P1 KS "" "" "")
                   (command "insert" "c:/dwg/fm02" P1 KS "" "" "")
                  (t (command "insert" "c:/dwg/fm01" P1 KS "" ANG ""))
                )                        ;cond end
              )                                ;progn3 end
            )                                ;if3 end
          )                                ;progn2 end
        )                                ;if2 end
      )                                        ;progn1 end
      (setq !ZF t)
    )                                        ;if1 end
    (setvar "aperture" 10)
  )                                        ;while end
  (grtext)
发表于 2002-10-25 17:07:00 | 显示全部楼层
(setq en (entsel "\n选择闸阀插入点:")) 这句有问题.
应用getpoint得到点,entsel是获取一个实体.
 楼主| 发表于 2002-10-25 22:17:00 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2013-4-27 14:10:18 | 显示全部楼层
龙大,我试了一下,一直提示找不到图,但我自己试着画了一个图放在那里了,也设置了支持路径
GMT+8, 2025-12-18 18:11 , Processed in 0.171815 second(s), 19 queries , Gzip On.
