查看: 1883|回复: 2
Lisp大夫请进...
发表于 2005-1-11 14:24:00 | 显示全部楼层 |阅读模式
以下程序想实现这样的动作:旋转坐标系,然后将所选的图块转回来使之看起来象没有变化一样(例如文字方向)。 有两个问题: 1、在(RoB311)里的(entmod)不会工作, 2、若想多次执行后图块仍可方向保持正确,应如何修改呢? 多谢指点! (defun C:RoViewPort(/ aunit c s)
(if (setq a (getangle"\n第一点将在新视图左侧,第二点在右侧..."))
(setvar "cmdecho" 0)
(setq aunit (getvar "AUNITS") )
(setvar "AUNITS" 3)
(setq c (getvar"VIEWCTR") s (getvar"VIEWSIZE") ) (if (wcmatch (findfile "acad.exe") "*R14*")
(command "ucs" "z" a)
(command "ucs" "n" "z" a)
(command "plan" "")
(command "ucs" "")
(command "zoom" "c" c s )
(princ"\n选择图块...")
(ROB311 a)
(setvar "AUNITS" aunit)
(setvar "cmdecho" 1)
) (defun ROB311(aa / ss n old_list entname zkname pt oldangle newangle )
(if (setq ss (ssget '(0 . "insert")))
(setq n 0)
(princ"\nThe Selections are...\n")
(while (<= n (- (sslength ss) 1))
(setq old_list (entget (ssname ss n))
entname (cdr (assoc -1 old_list))
pt (cdr (assoc 10 old_list))
oldangle (cdr (assoc 50 old_list))
newangle aa
(IF (ASSOC 66 old_list)
(setq zkname (cdr (assoc 1 (entget (entnext entname)))) )
(setq zkname "*" )
;这两句为什么不动作呢? ;(setq old_list (subst (cons 50 newangle) (assoc 50 old_list) old_list))
;(entmod old_list)
;暂用此法
(command "rotate" entname "" pt newangle )
(princ(strcat ">>" zkname ))
(setq n (+ n 1))
);if
发表于 2005-1-12 09:05:00 | 显示全部楼层
你再试试吧,我不是很清楚的过程,不过使用你注释掉的部分和原程序执行结果是一样的
发表于 2022-9-27 11:09:20 | 显示全部楼层
亡羊补牢,学而不晚,走走看看
GMT+8, 2026-1-16 04:16 , Processed in 0.156129 second(s), 25 queries , Gzip On.
