楼主: galayan
VB下如何编程隐藏AutoCAD的菜单跟工具栏?
发表于 2005-4-28 15:30:00 | 显示全部楼层
这个函数是windowAPI函数,你要声明一下的.在module里面加上这句话:        Public Declare Function SetMenu Lib "user32" (ByVal hwnd As Long, ByVal hMenu As Long) As Long
 楼主| 发表于 2005-4-28 16:49:00 | 显示全部楼层
出来了
谢谢!!!!!!!!!!!
发表于 2011-6-29 10:02:16 | 显示全部楼层
Sub ShHiToolbars() '显示或隐藏工具栏
     'Dim Button As AcadToolbarItem
        Dim Toolbar0 As AcadToolbar
        Dim MenuGrout0 As AcadMenuGroup
        'Dim SmallButtonName As String
        'Dim LargeButtonName As String
        'Dim ButtonType As String
        Set MenuGrout0 = ThisDrawing.Application.MenuGroups.Item(0)
        Set Toolbar0 = MenuGrout0.Toolbars.Item("测量剖面计算")
        Toolbar0.Visible = Not Toolbar0.Visible = True
End Sub
发表于 2011-6-29 20:01:42 | 显示全部楼层
显示或隐藏CAD所有工具条
For i = 0 To MenuGrout0.Toolbars.Count - 1
      MenuGrout0.Toolbars.Item(i).Visible = False  '隐藏
   'MenuGrout0.Toolbars.Item(i).Visible = True  '显示
Next i
发表于 2011-7-26 17:27:11 | 显示全部楼层
有没有办法只隐藏(或失效)菜单、工具栏中的某一项?
发表于 2011-7-29 21:35:05 | 显示全部楼层
    Dim curMenuGroup As AcadMenuGroup
    Set curMenuGroup = ThisDrawing.Application.MenuGroups.Item(0)
    Dim curMenu As AcadPopupMenu
        Set curMenu = curMenuGroup.Menus.Item("计算标注(&J)")
        Set menuItem = curMenu.Item("ID_分层计算面积")
        menuItem.Enable = False
        Set menuItem = curMenu.Item("ID_方量计算")
GMT+8, 2026-1-18 12:47 , Processed in 0.134902 second(s), 17 queries , Gzip On.
