查看: 1974|回复: 0
[讨论]讨论代码!急!
发表于 2002-12-21 16:46:00 | 显示全部楼层 |阅读模式
下面一段代码为什么不能显示填充图案???
Adesk::Boolean zmyrectangle::worldDraw(AcGiWorldDraw* mode)
        assertReadEnabled();
        // TODO: implement this function.
        AcGePoint3d Pts[2];
        AcGePoint3d pt[4];
        AcDbObjectId lineId0;
        AcDbObjectId lineId1;
        AcDbObjectId lineId2;
        AcDbObjectId lineId3;
        AcDbObjectIdArray dbObjIds;
    AcDbLine *line0;
        AcDbLine *line1;
        AcDbLine *line2;
        AcDbLine *line3;
        point(pt);
        Pts[0].x=pt[0].xts[0].y=pt[0].yts[0].z=0;
        Pts[1].x=pt[1].xts[1].y=pt[1].yts[1].z=0;
        line0=new AcDbLine(Pts[0],Pts[1]);
        line0->worldDraw(mode);
        //line->postToDb(line, lineId);
    dbObjIds.append(lineId0);
        Pts[0].x=pt[1].xts[0].y=pt[1].yts[0].z=0;
        Pts[1].x=pt[2].xts[1].y=pt[2].yts[1].z=0;
        line1=new AcDbLine(Pts[0],Pts[1]);
        line1->worldDraw(mode);
    dbObjIds.append(lineId1);
        Pts[0].x=pt[2].xts[0].y=pt[2].yts[0].z=0;
        Pts[1].x=pt[3].xts[1].y=pt[3].yts[1].z=0;
        line2=new AcDbLine(Pts[0],Pts[1]);
        line2->worldDraw(mode);
    dbObjIds.append(lineId2);
        Pts[0].x=pt[3].xts[0].y=pt[3].yts[0].z=0;
        Pts[1].x=pt[0].xts[1].y=pt[0].yts[1].z=0;
        line3=new AcDbLine(Pts[0],Pts[1]);
        line3->worldDraw(mode);
    dbObjIds.append(lineId3);
        AcDbHatch *pHatch=new AcDbHatch();
        AcGeVector3d normal(0.0, 1.0, 0.0);
    pHatch->setNormal(normal);
    //pHatch->setElevation(0.0);
    // Set hatch pattern to ANSI31 predefined type
    pHatch->setPattern(AcDbHatch::kPreDefined, "ANSI31");
    // Set Associativity
   // pHatch->setAssociative(Adesk::kTrue);
    // Append an internal loop (circle) to hatch boundary
    //pHatch->appendLoop(AcDbHatch::kDefault, dbObjIds);
        pHatch->appendLoop(AcDbHatch::kExternal, dbObjIds);
        pHatch->worldDraw(mode);
        // Elaborate hatch lines
    pHatch->evaluateHatch();
        // Post hatch entity to database
    //pHatch->postToDb(pHatch);
        delete pHatch;
        delete line0;
        delete line1;
        delete line2;
        delete line3;
        return Acad::eOk;
GMT+8, 2026-1-11 04:16 , Processed in 0.177143 second(s), 24 queries , Gzip On.
