查看: 1827|回复: 1
帮忙:查找错误,一个VBA中的数据库技术的程序。谢谢
发表于 2005-7-15 21:32:00 | 显示全部楼层 |阅读模式
 这个程序是照着书复制的,但编译的时候,还是有问题
系统提示红色的地方有问题,麻烦各位大侠帮忙,小弟不胜感激
Public Sub CreateDatabase()
    Dim NewWs As Workspace
    Set NewWs = DBEngine.Workspaces(0)
    Dim NewDb As Database
    Dim mdbName As String
    mdbName = CurDir() & "\SAMPLE\Authors.mdb"
    Set NewDb = NewWs.CreateDatabase(mdbName, dblangGeneral)
    Dim NewTbl1 As TableDef, NewTbl2 As TableDef
    Set NewTbl1 = NewDb.CreateTableDef("Youth")
    Set NewTbl2 = NewDb.CreateTableDef("Works")
    Dim F1 As Field, F2 As Field, F3 As Field, F4 As Field
    Dim F5 As Field, F6 As Field, F7 As Field, F8 As Field
    Dim F9 As Field, F10 As Field, F11 As Field
    Set F1 = NewTbl1.CreateField("AuthorID", dbText, 6)
    Set F2 = NewTbl1.CreateField("FirstName", dbText, 20)
    Set F3 = NewTbl1.CreateField("LastName", dbText, 20)
    Set F4 = NewTbl1.CreateField("Age", dbInteger)
    Set F5 = NewTbl1.CreateField("Address", dbText, 30)
    Set F6 = NewTbl1.CreateField("City", dbText, 20)
    Set F7 = NewTbl1.CreateField("Proviance", dbText, 20)
    Set F8 = NewTbl1.CreateField("Phone", dbText, 10)
    Set F9 = NewTbl1.CreateField("Email", dbText, 20)
    Set F10 = NewTbl2.CreateField("AuthorID", dbText, 6)
    Set F11 = NewTbl2.CreateField("WorksName", dbText, 30)
    NewTbl1.ValidationRule = "Age > 0"
    NewTbl1.ValidationText = "职员年龄不能小于零!"
    NewTbl1.Fields.Append F1
    NewTbl1.Fields.Append F2
    NewTbl1.Fields.Append F3
    NewTbl1.Fields.Append F4
    NewTbl1.Fields.Append F5
    NewTbl1.Fields.Append F6
    NewTbl1.Fields.Append F7
    NewTbl1.Fields.Append F8
    NewTbl1.Fields.Append F9
    NewTbl2.Fields.Append F10
    NewTbl2.Fields.Append F11
    NewDb.TableDefs.Append NewTbl1
    NewDb.TableDefs.Append NewTbl2
    NewDb.Close
    Set NewDb = Nothing
End Sub
发表于 2005-7-18 13:08:00 | 显示全部楼层
如果你因用的为“Microsoft DAO 3.51 Object Library”上面的代码没有问题的。
如果你因用的为“Microsoft DAO 3.6 Object Library”的话,那么
应改为
Set NewDb = NewWs.CreateDatabase(mdbName, dblangGeneral,dbEncrypt)
GMT+8, 2026-1-3 06:18 , Processed in 0.150747 second(s), 24 queries , Gzip On.
