查看: 2280|回复: 2
下标越界
发表于 2005-8-5 15:52:00 | 显示全部楼层 |阅读模式
Sub Line_Equation(ByRef LParam() As Double, ByVal p1 As Variant, ByVal p2 As Variant)
    LParam(0) = p2(1) - p1(1)
    LParam(1) = p1(0) - p2(0)
    LParam(2) = -1# * LParam(0) * p1(0) - LParam(1) * p1(1)
End Sub
上面是VB代码,我生成DLL文件,然后在VIsual Lisp 中插入
代码如下
(setq dllfile (findfile "d:\\vb\\dll\\linecircle.dll"))
(vlax-import-type-library :tlb-filename dllfile :methods-prefix "LCM-"
  :Properties-prefix "LCM-"  :constants-prefix "LCM-" )
(setq lcobj (vlax-get-or-create-object "linecircle.calculate"))
(setq arr1 (vlax-make-safearray vlax-vbvariant '(0 . 1)))
(vlax-safearray-fill arr1 '(1.0 1.0 ))
(setq arr2 (vlax-make-safearray vlax-vbvariant '(0 . 1)))
(vlax-safearray-fill arr2 '(2.0 3.0 ))
(vlax-invoke-method  lcobj  "Line_Equation"  'line1 arr1  arr2)
错误如下:
error: Automation Error. 下标越界
其它在VB中没有用到ByRef 的可正常使用
请问是什么问题啊?怎么解决?
发表于 2005-8-5 21:45:00 | 显示全部楼层
line1没有定义,创建一个0-2的数组,不要赋值试试。
 楼主| 发表于 2005-8-8 08:38:00 | 显示全部楼层
谢谢efan2000!!
(setq line1 (vlax-make-safearray vlax-vbvariant '(0 . 2)))
(setq line1 (vlax-make-safearray vlax-vbdouble '(0 . 2)))
(setq line1 (vlax-make-safearray vlax-vbempty '(0 . 2)))
(setq line1 (vlax-make-safearray vlax-vbobject '(0 . 2)))
我试了好多种数据类型,都不行,出错如下
error: Automation Error. 类型不匹配
后来我加了下面一句还是一样,请帮忙再想想会是什么原因!!!
(setq line1 (vlax-make-variant line1 ))
GMT+8, 2025-12-27 04:33 , Processed in 0.159790 second(s), 23 queries , Gzip On.
