楼主: zhongguola
寻求提取坐标的帮助
发表于 2005-8-23 12:26:00 | 显示全部楼层
好像调试通过不了,不会用,能不能讲一下,谢了
 楼主| 发表于 2005-8-23 14:41:00 | 显示全部楼层
不会吧?
我刚用过的很好用!
先加载此程序
再选择多义线,然后再CAD屏幕任意地方点击一下,就可标注出多义线的坐标,真的很好用。
发表于 2005-9-8 20:48:00 | 显示全部楼层
(defun c:tjzb()
    (setq cm (getvar "cmdecho"))
    (setvar "cmdecho" 0)
    (setq ff (open (getfiled "请指定坐标数据存盘文件" "" "txt" 1) "w")
   p1 (getpoint "\n请指定提取范围左上角:")
   p2 (getcorner p1 "\n请指定提取范围右上角:")
    (if (setq sa (ssget "未命名" p1 p2 '((0 . "POINT"))))
    (setq n (sslength sa) i 0)
    (repeat n
       (setq db (cdr (assoc 10 (entget (ssname sa i)))) i (1+ i))
       (princ (strcat (rtos (car db)  2 5) " , "
        (rtos (cadr db) 2 5) " , "
        (rtos (last db) 2 5) "\n"
       ff
         (alert "所指定范围内没有点")
     (close ff)
     (setvar "cmdecho" cm)(princ)
 楼主| 发表于 2005-9-12 17:23:00 | 显示全部楼层
这个程序根本就不能应用,在命令行提示:参数太少
GMT+8, 2025-12-19 03:22 , Processed in 0.158328 second(s), 20 queries , Gzip On.
