楼主: liu22737
带对话框的圆坐标列表程序
 楼主| 发表于 2005-9-15 20:05:00 | 显示全部楼层
源码
 回复七楼:
忘记加载我的通用函数;
我又传一个。你再试一下。
不支持中文图层
发表于 2005-9-15 23:14:00 | 显示全部楼层
小兄弟,你用的图层有点象 富金的图层似的
发表于 2005-9-16 23:09:00 | 显示全部楼层
yedajiang兄指点
(defun c:test (/ lst)
  (vl-load-com)
  (if (ssget '((0 . "circle")))
      (setq *AcadDocument* (vla-Get-ActiveDocument (vlax-Get-Acad-Object)))
      (vla-StartUndoMark *AcadDocument*)
      (if (setq lst (GetLst))
 (Display lst)
      (vla-EndUndoMark *AcadDocument*)
(defun Display (lst / TextPt i pt Text StrDia Dia)
  (while (not (setq TextPt (Getpoint "\nPlease Specify a point : "))))
  (setq old_cmdecho (getvar "cmdecho")
 old_osmode  (getvar "osmode")
  (setvar "cmdecho" 0)
  (setvar "osmode" 0)
  (setq i 0)
  (foreach en lst
    (setq pt   (vlax-safearray->list
   (vlax-variant-value (vla-get-center (vlax-ename->vla-object (handent (cadr en)))))
   i    (1+ i)
   Text (strcat "No" (itoa i))
    (command "text" pt 3.5 0 Text)
    (setq StrDia "")
    (foreach hn (cdr en)
      (setq Dia    (vla-Get-Diameter (vlax-ename->vla-object (handent hn)))
     StrDia (strcat strDia " " (rtos Dia 2 2))
    (setq StrDia (strcat Text " " (rtos (car pt) 2 2) " " (rtos (cadr pt) 2 2) " " strDia))
    (setq TextPt (list (car TextPt) (- (cadr TextPt) 6)))
    (command "text" TextPt 3.5 0 StrDia)
  (setvar "cmdecho" old_cmdecho)
  (setvar "osmode" old_osmode)
(defun GetLst (/ ss pt hand lst)
  (setq ss (vla-Get-ActiveSelectionset *AcadDocument*))
  (setq lst '())
  (vlax-for en ss
    (setq pt   (vlax-safearray->list (vlax-variant-value (vla-get-center en)))
   hand (vla-get-handle en)
    (if (assoc pt lst)
      (setq lst (subst (append (assoc pt lst) (list hand)) (assoc pt lst) lst))
      (setq lst (append lst (list (list pt hand))))
  lst
[/QUOTE]
发表于 2005-9-17 10:12:00 | 显示全部楼层
HuaiYu发表于2005-9-16 23:09:00 请yedajiang兄指点 (defun c:test (/ lst)(vl-load-com)(if (...
后天就要出差了,可能没有空详细去理解你程序。十月份回来后一定给你提些建议。请你自己也多关注。
 楼主| 发表于 2005-9-24 22:28:00 | 显示全部楼层
哪个富金,富士康吗
发表于 2006-2-5 18:56:00 | 显示全部楼层
求助,自动画三视图LISP
发表于 2007-12-30 19:43:00 | 显示全部楼层
谢谢大大,我想学,可不知道怎么开始,唉~!
发表于 2007-12-30 20:00:00 | 显示全部楼层
个人比较喜欢liu22737大大编写的,其他大大的我用不会啊。
发表于 2008-4-26 15:02:00 | 显示全部楼层
谢谢,下载用了
发表于 2008-5-6 07:02:00 | 显示全部楼层
谢谢,我喜欢源码来的,能够学习学习吗
GMT+8, 2026-1-15 11:37 , Processed in 0.196851 second(s), 19 queries , Gzip On.
