查看: 1784|回复: 2
请问如何在命令行交互输入字符串?
发表于 2005-11-14 10:32:00 | 显示全部楼层 |阅读模式
请问如何在命令行交互输入字符串?我想对某一层进行操作,用"Getstring",输入层名时总是出错。
发表于 2005-11-14 16:49:00 | 显示全部楼层
<RE class=Code>Utility.GetString</PRE><RE class=Code>AutoCAD里有帮助</PRE><RE class=Code>Sub Example_GetString()
    ' This example demonstrates different ways of returning a string
    ' entered by a user.
    Dim returnString As String
    ' Prompt &amp; Input cannot contain blanks
    returnString = ThisDrawing.Utility.GetString(False, "Enter text (a space or &lt;enter&gt; terminates input): ")
    MsgBox "The string entered was '" &amp; returnString &amp; "'", , "GetString Example"
    ' Prompt &amp; Input can contain blanks
    returnString = ThisDrawing.Utility.GetString(True, "Enter text (&lt;enter&gt; terminates input):")
    ' Prompt &amp; Input can contain blanks, but not an empty string
    Dim NoNull As Integer
    NoNull = 1    ' Disallow null
    ThisDrawing.Utility.InitializeUserInput NoNull
    returnString = ThisDrawing.Utility.GetString(True, "Enter text (&lt;enter&gt; terminates input): ")
End Sub</PRE>
 楼主| 发表于 2005-11-15 13:22:00 | 显示全部楼层
谢谢
GMT+8, 2026-1-16 02:51 , Processed in 0.156653 second(s), 23 queries , Gzip On.
