楼主: blue123
[LISP]如何获取图元的颜色索引号
 楼主| 发表于 2005-11-21 19:40:00 | 显示全部楼层
其实我想编一个专门用来删同一色图元的程式,现在搞定了,谢谢二位,ZZXXQQ和飞哥。程式如下:
(DEFUN C:GETCL(/ S1)
 (SETQ S1 (ENTSEL "\nSelect a object 选择一个实体 :"))
 (if (not (ASSOC 62 (ENTGET (CAR S1)))) (setq ss (ssget "x" '((62 . 256))))
 (setq ss (ssget "x"(list (ASSOC 62 (ENTGET (CAR S1))))))
 (command "erase" ss "")
发表于 2005-11-21 21:41:00 | 显示全部楼层
(SSGET "X" '((62 . 256)))只是选择了全部颜色随图层的实体,有可能误删除不同颜色的实体。
 楼主| 发表于 2005-11-22 21:11:00 | 显示全部楼层
请教该如何解决呢?
发表于 2005-11-23 21:39:00 | 显示全部楼层
  1. (DEFUN C:GETCL(/ S1)
  2. (SETQ S1 (ENTSEL "\nSelect a object 选择一个实体 :"))
  3. (if (not (ASSOC 62 (ENTGET (CAR S1))))
  4.   (setq ss (ssget "x" (LIST (ASSOC 8 (ENTGET (CAR S1))) (CONS 62 256))))
  5.   (setq ss (ssget "x" (list (ASSOC 62 (ENTGET (CAR S1))))))
  6. )
  7. (command "erase" ss "")
  8. )
发表于 2005-11-25 09:06:00 | 显示全部楼层
;以前和大家讨论的结果
;;; 图层的颜色
;;; 返回层的颜色
(defun th1-get-color (laname / la1 la col)
  (setq la (cdr (assoc 2 (tblnext "layer" t))))
  (while (/= la laname)
    (setq la1 (tblnext "layer" nil)
   la (cdr (assoc 2 la1))
   col (cdr (assoc 62 la1))
  (princ "\n颜色为 : ")
  col
;;; 返回实体颜色
(defun th2-get-color (ename / ent col)
  (setq ent (entget ename))
  (or
    (setq col (cdr (assoc 62 ent)))
    (setq col (cdr (assoc 62 (tblsearch "layer" (cdr (assoc 8 ent))))))
  col
(defun th3-get-color (ename / ent col)
  (cond
    ((setq col (cdr (assoc 62 ent))))
    ((setq col (cdr (assoc 62 (tblsearch "layer" (cdr (assoc 8 ent)))))))
;;; 求实体所在层和颜色,返回(层名  颜色)
(defun th1-get-layandcol (ename / b col doc lay layobj)
  (vl-load-com)
  (setq b (vlax-ename->vla-object ename))
  (setq lay (vla-get-layer b))
  (setq col (vla-get-color b))
  (if (= col 256)
      (setq doc (vla-get-activedocument (vlax-get-acad-object)))
      (setq layobj (vla-item (vla-get-layers doc) lay))
      (setq col (vla-get-color layobj))
  (list lay col)
(defun th2-get-layandcol (ename / ent col)
  (setq lay (cdr (assoc 8 ent)))
  (cond
  (list lay col)
(defun th3-get-layandcol (ename / ent col)
  (cond
  (if (cdr (assoc 62 ent))
    (list lay col)
    (list lay col "bylayer")
GMT+8, 2025-12-18 01:12 , Processed in 0.183140 second(s), 18 queries , Gzip On.
