楼主: 小顽童
[求助]这样的填充效果如何用VBA实现?
 楼主| 发表于 2005-11-22 21:23:00 | 显示全部楼层
8楼的大哥,我把代码帖上来了,添加内边界老是出错,请你指导一下,非常感谢!
Sub HH()
'On Error Resume Next
Dim ent As AcadEntity
Dim Pname As String
Dim Ptype As Long
Dim Ba As Boolean
Dim Hatchobj As AcadHatch
Pname = "ANSI33" '填充样式
Ptype = acHatchPatternTypePreDefined '填充类型
Ba = True '是否关联
Dim Outer(0 To 0) As AcadEntity
Dim i As Integer
Dim j As Integer
Dim s As Integer
Dim Plobj As AcadPolyline
Dim coor As Variant
Dim coords As Variant
Dim pnt As Variant
Dim Sset As AcadSelectionSet
'clearsset
Set Sset = ThisDrawing.SelectionSets.Add("GD")
ThisDrawing.Utility.GetEntity ent, pnt, "c"
coords = ent.Coordinates
Sset.SelectByPolygon acSelectionSetWindowPolygon, coords
Dim K As Integer
ReDim Inner(0 To Sset.Count - 1) As AcadEntity
For K = 0 To Sset.Count - 1
    Set Inner(K) = Sset.Item(K)
Next
Sset.Delete
Set Outer(0) = ent '定义填充外边界
Set Hatchobj = ThisDrawing.ModelSpace.AddHatch(Ptype, Pname, Ba)
'Hatchobj.HatchStyle = acHatchStyleOuter
Hatchobj.AppendOuterLoop Outer
Hatchobj.AppendInnerLoop Inner
Hatchobj.Evaluate
ThisDrawing.Regen True
End Sub
发表于 2005-11-22 23:14:00 | 显示全部楼层
像你的例题的图像要调用Hatchobj.AppendInnerLoop 两遍
内外边界的图形要首尾相连且闭合
 楼主| 发表于 2005-11-23 18:54:00 | 显示全部楼层
L大哥,我的图形内外边界都是首尾相连,并且闭合,那我的代码有问题吗?
发表于 2009-6-18 20:10:00 | 显示全部楼层
生成外面的大面域,以及中间的两个黑色小面域,用大面域布尔运算减去里面两个小面域得到新的面域,用Addhatch填充就可以了。
发表于 2009-6-22 21:56:00 | 显示全部楼层
看看这个帖子吧,可能对你会有帮助http://www.boxuesky.com/read-htm-tid-25503.html
GMT+8, 2026-1-17 23:50 , Processed in 0.926662 second(s), 18 queries , Gzip On.
