楼主: bower
到底如何对话框中文本框动态付初值啊?我实在是没辙了!!!
发表于 2005-11-23 21:50:00 | 显示全部楼层
  1. (defun c:qudong_biaotilan()
  2. (setq mingcheng (if mingcheng mincheng "名称")
  3.        zhitu (if zhitu zhitu "制图"))
  4. (if (< (setq index (load_dialog "biaotilan.dcl")) 0) (exit))
  5. (if (not (new_dialog "biaotilan" index)) (exit))
  6. (set_tile "mingcheng" mingcheng)
  7. (set_tile "zhitu" zhitu)
  8. (action_tile "accept" "(readdata) (done_dialog 3)")
  9. (action_tile "cancel" "(done_dialog 4)")
  10. (action_tile "help" "(help)")
  11. (setq result (start_dialog))
  12. (unload_dialog index)
  13. (if (= result 3) (progn
  14.   (load "biaotilan.lsp")
  15.   (set_tile "mingcheng" mingcheng);得到填入文本框中的值。
  16.   (set_tile "zhitu" zhitu)  ;得到填入文本框中的值。
  17.   (biaotilan mingcheng zhitu)
  18. ))
  19. (princ)
  20. )
  21. (defun readdata ()
  22. (setq zhitu (get_tile "zhitu")
  23.        mingcheng (get_tile "mingcheng"))
  24. )
发表于 2011-9-18 21:14:19 | 显示全部楼层
如果是全局变量,那另外一个lisp如果也有同名的全局变量的话会有冲突哈!
GMT+8, 2025-12-16 18:24 , Processed in 0.163520 second(s), 19 queries , Gzip On.
