使用TrueColor属性:
Sub TrueColor_Test() ' This example draws a line and returns the RGB values Dim color As AcadAcCmColor Set color = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor.16") Call color.SetRGB(80, 100, 244) Dim line As AcadLine Dim startPoint(0 To 2) As Double Dim endPoint(0 To 2) As Double startPoint(0) = 1#: startPoint(1) = 1#: startPoint(2) = 0# endPoint(0) = 5#: endPoint(1) = 5#: endPoint(2) = 0# Set line = ThisDrawing.ModelSpace.AddLine(startPoint, endPoint) ZoomAll line.TrueColor = color
End Sub |
