查看: 2259|回复: 4
[求助]两直线间角度
发表于 2005-12-9 09:24:00 | 显示全部楼层 |阅读模式
我想一次输入两条成一定角度的直线,不知怎么输入命令。
还请诸位帮忙。谢谢!
发表于 2005-12-9 11:36:00 | 显示全部楼层
;在CAD中好像不太好实现,要是程序倒是简单得很。试试下面的
(defun c:double-line ()
(setvar "osmode" 0)
(setq L1 (getdist "\n第一条直线的长度:"))
(setq L2 (getdist "\n第二条直线的长度:"))
(setq ang (getreal "\n相交角度:"))
(setq ang (* pi (/ ang 180)))
(setq p (getpoint "\n插入点:"))
(setq p1 (polar p 0 L1))
(setq p2 (polar p ang L2))
(command "_.pline" p1 "h" "0" "0" p p2 "")
发表于 2005-12-10 16:04:00 | 显示全部楼层
学习楼上的
发表于 2005-12-10 19:15:00 | 显示全部楼层
呵呵,非得一次画两天吗?清华同方软件可以,CAD没试过,可是你COPY后在旋转也就几秒钟的时间啊.
 楼主| 发表于 2005-12-11 09:15:00 | 显示全部楼层
多谢了,学习中。
GMT+8, 2026-1-15 04:13 , Processed in 0.187127 second(s), 28 queries , Gzip On.
