查看: 1889|回复: 1
求助!怎么样设置标注样式的比例?
发表于 2005-12-13 19:50:00 | 显示全部楼层 |阅读模式
 图形中有 "STANDARD","CAD"....的标注样式,我想设置他们标注比例,以及其它属性,用VBA怎么实现.
下面是我做的对 "STANDARD" 比例的修改,可以运行后,出现一个对应的,"样式替代"
Dim adDimStyle As AcadDimStyle
  For Each adDimStyle In ThisDrawing.DimStyles
       If adDimStyle.Name = "STANDARD" Then
         ThisDrawing.ActiveDimStyle = adDimStyle
    End If
  Next
  With ThisDrawing
    .SetVariable "DimScale", 96
  End With
发表于 2005-12-14 09:14:00 | 显示全部楼层
把With ThisDrawing
  End With
换为:
ThisDrawing.SetVariable "DIMSCALE", 96
ThisDrawing.DimStyles.Item("Sca96"Delete
Set NewTxtStyle = ThisDrawing.DimStyles.Add( "Sca96")
NewTxtStyle.CopyFrom ThisDrawing
GMT+8, 2026-1-16 04:03 , Processed in 4.193959 second(s), 23 queries , Gzip On.
