楼主: wuyidebh
大家帮我看看这个怎么实现,谢谢
发表于 2005-12-30 21:16:00 | 显示全部楼层
必须关闭捕捉
发表于 2005-12-31 10:27:00 | 显示全部楼层
这样一个画标准件的程序应该越简单越好.要求输入那么多的参数,这样LISP显示不出它的长处了.
下面是依据相关标准制作的内六角螺钉程序,只需用户输入起点与终点和螺丝直径即可.其它由程序决定.
注意:使用以下程序需要你的CAD文档中具有相关图层(虚线和细实线这两个图层)及相关的多线样式(standard).
;;;内六角螺钉程序
(defun c:nd()
  (setq pt1 (getpoint "\n 请输入起点:"))
  (setq pt2 (getpoint pt1 "\n 请输入终点:"))
  (setq d (getdist "\n 请输入螺栓直径d<10>:"))
  (setq YH_osmode (getvar "osmode"))
  (setvar "osmode" 0)
  (if (null d) (setq d 10))
  (setq ang (angle pt1 pt2))
  (setq pt3 (polar pt2 (+ ang pi) (* d 0.075)))
  (setq pt4 (polar pt1 (+ ang pi) d))
  (setq pt5 (polar pt3 (+ ang (* pi 0.5)) (* d 0.5)))
  (setq pt6 (polar pt2 (+ ang (* pi 0.5)) (* d 0.425)))
  (setq pt7 (polar pt2 (+ ang (* pi 1.5)) (* d 0.425)))
  (setq pt8 (polar pt3 (+ ang (* pi 1.5)) (* d 0.5)))
  (setq pt9 (polar pt4 ang (* d 0.4)))
  (setq pt10 (polar pt4 ang (* d 0.45)))
  (cond ((= d 2.5) (setq e 2.3) (setq dk 4.5))
 ((= d 3) (setq e 2.87) (setq dk 5.3))
 ((= d 4) (setq e 3.44) (setq dk 7))
 ((= d 5) (setq e 4.58) (setq dk 8.5))
 ((= d 6) (setq e 5.72) (setq dk 10))
 ((= d 8) (setq e 6.86) (setq dk 13))
 ((= d 10) (setq e 9.15) (setq dk 16))
 ((= d 12) (setq e 11.43) (setq dk 18))
 ((= d 14) (setq e 13.72) (setq dk 21))
 ((= d 16) (setq e 16) (setq dk 24))
 (t (setq e 9.15) (setq dk 16))
  (setq pt11 (polar pt10 (+ (* 0.5 pi) ang) (* e 0.375)))
  (setq pt12 (polar pt10 (+ (* 1.5 pi) ang) (* e 0.375)))
  (setq pt13 (polar pt9 (+ (* 0.5 pi) ang) (* e 0.5)))
  (setq pt14 (polar pt9 (+ (* 0.5 pi) ang) (* e 0.25)))
  (setq pt15 (polar pt9 (+ (* 1.5 pi) ang) (* e 0.25)))
  (setq pt16 (polar pt9 (+ (* 1.5 pi) ang) (* e 0.5)))
  (setq pt17 (polar pt1 (+ (* 0.5 pi) ang) (* dk 0.5)))
  (setq pt18 (polar pt1 (+ (* 1.5 pi) ang) (* dk 0.5)))
  (setq pt19 (polar pt18 (+ pi ang) d))
  (setq pt20 (polar pt17 (+ pi ang) d))
    ;;;下面开始绘制
  (command "mline" "j" "z" "s" (* d 0.85) "st" "k" pt1 pt2 "")
  (command "change" (entlast) "" "p" "la" "细实线" "")
  (command "mline" "j" "z" "s" d "st" "standard" pt1 pt3 "")
  (command "mline" "j" "z" "s" e "st" "standard" pt4 pt9 "")
  (command "change" (entlast) "" "p" "la" "虚线" "")
  (command "mline" "j" "z" "s" (* e 0.5) "st" "k" pt4 pt9 "")
  (command "pline" pt13 "a" "s" pt11 pt14 "s" pt10 pt15 "s" pt12 pt16 "")
  (command "pline" pt5 "w" 0 "" pt5 pt6 pt7 pt8 "c")
  (command "pline" pt17 "w" 0 "" pt20 pt19 pt18 "")
  (command "fillet" "r" (* d 0.1) "")
  (command "fillet" "p" (entlast))
  (command "line" pt17 pt18 "" "line" pt11 pt12 "")
  (command "pline" pt13 (polar pt9 ang (* (* e 0.5) (/ (sin (/ pi 6)) (cos (/ pi 6))))) pt16 "")
  (setvar "osmode" YH_osmode)
GMT+8, 2025-12-18 01:34 , Processed in 0.155681 second(s), 20 queries , Gzip On.
