查看: 1746|回复: 1
xdata
发表于 2003-2-8 15:29:00 | 显示全部楼层 |阅读模式
XDATA问题?请斑竹指教!
(defun c:xd ()
  (setq appidname "MOON")
  (IF (tblsearch "appid" appidname)
    (PRINC (STRCAT "/N" appidname))
    (PROGN
      (SETq REGISTER (REGAPP appidname))
      (IF (/= REGISTER nil)
        (PRINC (STRCAT "注册" appidname "成功"))
  (setQ A (entget (ssname (ssget) 0)))
  (setQ        KA '(-3 (APPNAME  (1000 . 85110) (1071 . 84110)
(setQ        xdataent (APPEND A (LIST KA)))
;;(setq        xdataent (APPEND A KA) )
  (entmod xdataent)
发表于 2003-2-8 17:05:00 | 显示全部楼层
[建议]
未执行你的程序,但错误有:
1、APPNAME未见申明;
2、1000后要接字符串;
3、列表不正确;
将(setQ KA '(-3 (APPNAME  (1000 . 85110) (1071 . 84110))))改为
(setQ KA (list -3 (list APPIDNAME  (cons 1000 "85110") (cons 1071 84110))))试试.
GMT+8, 2025-4-7 11:52 , Processed in 0.180089 second(s), 27 queries , Gzip On.
