查看: 1939|回复: 3
(求助)有关周长的问题,帮忙看一下代码
发表于 2006-3-27 16:03:00 | 显示全部楼层 |阅读模式
想求多个面域的累加周长,怎么做?有一段代码是求多个面域的累加面积的,程序正确.我把其中的area必成list ,想求周长,但运行时出错.
求累加面积的正确代码:
 ublic Sub carea()
  On Error GoTo ErrorHandler
  Dim pt As Variant
  Dim spt As String
  Dim i As Integer
  Dim zarea As Double
  zarea = 0
  For i = 0 To 500
   pt = ThisDrawing.Utility.GetPoint(, vbCrLf & "输入要计算面积对象的内部一点:")
   spt = pt(0) & "," & pt(1)
   With ThisDrawing
     SendCommand "-boundary "
     SendCommand spt & " "
     SendCommand " "
     SendCommand "area "
     SendCommand "o "
     SendCommand "last "
     SendCommand "erase "
     SendCommand "last "
     SendCommand " "
   End With
   zarea = zarea + ThisDrawing.GetVariable("AREA")
   ThisDrawing.Utility.Prompt vbCrLf & "选定对象的总面积为: " & zarea & vbCrLf
  Next
ErrorHandler:
  Exit Sub
End Sub
我改后的代码:
Public Sub clist()
  Dim pt As Variant
  Dim spt As String
  Dim i As Integer
  Dim zlist As Double
  zlist = 0
  For i = 0 To ThisDrawing.ModelSpace.Count
   pt = ThisDrawing.Utility.GetPoint(, vbCrLf & "输入要计算周长对象的内部一点:")
   With ThisDrawing
     SendCommand " "
     SendCommand "list"
     SendCommand "last "
     SendCommand "last "
     SendCommand " "
   End With
   zlist = ThisDrawing.GetVariable("list")
   ThisDrawing.Utility.Prompt vbCrLf & "选定对象的总面积为: " & zlist
  Next
ErrorHandler:
  Exit Sub
End Sub
请大家多多指教,不胜感激.
发表于 2006-3-27 16:42:00 | 显示全部楼层
  1. Public Sub clist()
  2.     Dim pt As Variant
  3.     Dim spt As String
  4.     Dim i As Integer
  5.     pt = ThisDrawing.Utility.getpoint(, vbCrLf & "输入要计算周长对象的内部一点:")
  6.     spt = pt(0) & "," & pt(1)
  7.     ThisDrawing.SendCommand "-boundary" & vbCr & "a" & vbCr & "o" & vbCr & "r" & vbCr & vbCr & spt & vbCr & vbCr
  8.     If (ThisDrawing.GetVariable("LASTPROMPT") <> "已创建 0 个面域。") Then
  9.         MsgBox ThisDrawing.ModelSpace(ThisDrawing.ModelSpace.Count - 1).Perimeter
  10.         ThisDrawing.ModelSpace(ThisDrawing.ModelSpace.Count - 1).Delete
  11.     End If
  12. End Sub
 楼主| 发表于 2006-3-27 22:11:00 | 显示全部楼层
我试过了,所有的内部面域都好用,但为什么最外的那个面域求得的结果不对呢,它的周长应该是最大的呀,可结果却是最小的
 楼主| 发表于 2006-3-27 22:13:00 | 显示全部楼层
GMT+8, 2026-1-9 04:04 , Processed in 0.150175 second(s), 24 queries , Gzip On.
