查看: 2738|回复: 9
提取blockreference中一个圆的方法
发表于 2006-5-18 22:47:00 | 显示全部楼层 |阅读模式
假如一个块中有一个圆及两条直线,我现在想得到块中圆的大小,请问用什么方法较好
望大师指点,谢谢
以下是acad帮助,为什么没有item这个属性
Methods MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_arraypolar.htm" target="_blank" >
ArrayPolar MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_arrayrectangular.htm" target="_blank" >
ArrayRectangular MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_copy.htm" target="_blank" >
Copy MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_delete.htm" target="_blank" >
Delete MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_explode.htm" target="_blank" >
Explode MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_getattributes.htm" target="_blank" >
GetAttributes MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_getboundingbox.htm" target="_blank" >
GetBoundingBox MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_getconstantattributes.htm" target="_blank" >
GetConstantAttributes MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_getextensiondictionary.htm" target="_blank" >
GetExtensionDictionary MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_getxdata.htm" target="_blank" >
GetXData MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_highlight.htm" target="_blank" >
Highlight MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_intersectwith.htm" target="_blank" >
IntersectWith MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_mirror.htm" target="_blank" >
Mirror MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_mirror3d.htm" target="_blank" >
Mirror3D MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_move.htm" target="_blank" >
Move MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_rotate.htm" target="_blank" >
Rotate MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_rotate3d.htm" target="_blank" >
Rotate3D MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_scaleentity.htm" target="_blank" >
ScaleEntity MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_setxdata.htm" target="_blank" >
SetXData MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_transformby.htm" target="_blank" >
TransformBy MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_update.htm" target="_blank" >
Update
Properties MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_application.htm" target="_blank" >
Application MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_document.htm" target="_blank" >
Document MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_hyperlinks.htm" target="_blank" >
Hyperlinks MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_handle.htm" target="_blank" >
Handle MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_hasattributes.htm" target="_blank" >
HasAttributes MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_hasextensiondictionary.htm" target="_blank" >
HasExtensionDictionary MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_insertionpoint.htm" target="_blank" >
InsertionPoint MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_layer.htm" target="_blank" >
Layer MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_linetype.htm" target="_blank" >
Linetype MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_linetypescale.htm" target="_blank" >
LinetypeScale MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_lineweight.htm" target="_blank" >
Lineweight MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_name.htm" target="_blank" >
Name MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_normal.htm" target="_blank" >
Normal MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_objectid.htm" target="_blank" >
ObjectID MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_objectname.htm" target="_blank" >
ObjectName MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_ownerid.htm" target="_blank" >
OwnerID MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_plotstylename.htm" target="_blank" >
PlotStyleName MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_rotation.htm" target="_blank" >
Rotation MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_TrueColor_property.htm" target="_blank" >
TrueColor MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_visible.htm" target="_blank" >
Visible MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_xscalefactor.htm" target="_blank" >
XScaleFactor MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_yscalefactor.htm" target="_blank" >
YScaleFactor MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_zscalefactor.htm" target="_blank" >
ZScaleFactor
Events MSITStore:D:\Program%20Files\AutoCAD%202005\help\acadauto.chm::/idh_modified.htm" target="_blank" >
Modified
发表于 2006-5-19 08:46:00 | 显示全部楼层
睽睽
发表于 2006-5-19 09:21:00 | 显示全部楼层
个人觉得从AcadBlockReference中提取圆的参数,困难!不过可以得到它的name,然后得到对应的AcadBlock,在它里面提取圆的参数就容易了,没办法,变通一下。。。。
发表于 2006-5-21 15:00:00 | 显示全部楼层
我也面临类似的问题,看到帮助中说可以先把块参照给分解,然后再读取对象,可是分解后不知道怎么组合块参照了
发表于 2006-5-22 09:51:00 | 显示全部楼层
To 4 楼:
帮助里说的如果要在块参照中添加或删除对象,必须要先炸开。。。。你这么理解倒也无可厚非,在前面怎么组合块参照也提到了
VBA class name:
AcadBlockReference
Create using:
ModelSpace.InsertBlock
PaperSpace.InsertBlock
Block.InsertBlock
Access via:
ModelSpace.Item
PaperSpace.Item
Block.Item
SelectionSet.Item
Group.Item
To create a block reference, first you must create a block definition, or block, by using the MSITStore:C:\Program%20Files\MDT6\HELP\ACADAUTO.CHM::/idh_add.htm" target="_blank" >Add method. Once created, you can insert an instance of this block into your drawing using the MSITStore:C:\Program%20Files\MDT6\HELP\ACADAUTO.CHM::/idh_insertblock.htm" target="_blank" >InsertBlock method.
意思就是说先在thisdrawing.application.activedocument.blocks中使用add增加一个块定义,然后用InsertBlock将分解后返回的对象添加到块定义中。。。。。
不过这种方法不太好,每提一回属性就要把块参照炸碎一回,这个不符合VBA的编程要求。。。。。
 楼主| 发表于 2006-5-22 16:51:00 | 显示全部楼层
在此先谢3楼楼主
发表于 2006-5-22 19:06:00 | 显示全部楼层
也许先在块定义前,获取块内对象的句柄,这样就通过句柄查看可能好些
发表于 2006-5-23 16:29:00 | 显示全部楼层
应该根据块参照的name属性,得到相应的块,然后取得块中圆的大小.得到块中圆的大小后,还需要检索块属性的scalefactor属性,可以知道块参照放大缩小的比例,然后就可以知道圆有多少大了.
发表于 2006-5-24 08:14:00 | 显示全部楼层
楼上说的很对,还要检测scalfactor属性,顶顶!
 楼主| 发表于 2006-5-25 16:03:00 | 显示全部楼层
這麼多大師能幫忙,真的感謝
GMT+8, 2026-1-16 10:35 , Processed in 0.177017 second(s), 23 queries , Gzip On.
