查看: 1324|回复: 0
高手们,进来看看啊,你们举手就能解决的问题
发表于 2006-5-27 08:42:00 | 显示全部楼层 |阅读模式
各位高手:
      我想利用三维多段线,通过拉伸一个圆环,在三维空间中生成管道,帮我看看程序哪里有问题,多谢了啊
Sub pipe()
   Dim circle1(0) As AcadEntity
   Dim circle2(0) As AcadEntity
   Dim regionObj1 As Variant
   Dim regionObj2 As Variant
   Dim point1(0 To 11) As Double
   Dim point2(0 To 2) As Double
   Dim radius1 As Double
   Dim radius2 As Double
   Dim line1 As Acad3DPolyline
   Dim solidObj As Acad3DSolid
   point1(0) = 0
   point1(1) = 0
   point1(2) = 0
   point1(3) = 100
   point1(4) = 0
   point1(5) = 0
   point1(6) = 100
   point1(7) = 100
   point1(8) = 0
   point1(9) = 100
   point1(10) = 100
   point1(11) = 100
   radius1 = 7
   radius2 = 5
   '创建面域
   Set circle1(0) = ThisDrawing.ModelSpace.AddCircle(point1, radius1)
   Set circle2(0) = ThisDrawing.ModelSpace.AddCircle(point1, radius2)
   regionObj1 = ThisDrawing.ModelSpace.AddRegion(circle1)
   regionObj2 = ThisDrawing.ModelSpace.AddRegion(circle2)
   '布尔运算
   regionObj1(0).Boolean acSubtraction, regionObj2(0)
   '拉伸路径
   Set line1 = ThisDrawing.ModelSpace.Acad3DPolyline(point1)
   Set solidObj = ThisDrawing.ModelSpace.AddExtrudedSolidAlongPath(regionObj1(0), line1)
End Sub
GMT+8, 2026-1-16 10:33 , Processed in 3.804913 second(s), 23 queries , Gzip On.
