查看: 4196|回复: 3
[求助]当文字是插入的块时,如何用VBA编程序得到其字符.-->mccad转移
发表于 2002-4-28 20:52:00 | 显示全部楼层 |阅读模式
有时文字是从别的图中复制-粘贴的,如果不打破的话,能否直接得到文字内容.
发表于 2002-4-28 21:05:00 | 显示全部楼层
记住,在VBA中,模型空间和图纸空间也是图块,所以操作方法可以一样,只是针对的对
记住,在VBA中,模型空间和图纸空间也是图块,所以操作方法可以一样,只是针对的对象不同[br]
 楼主| 发表于 2002-5-1 10:21:00 | 显示全部楼层
我就是不知道该用什么对象的什么属性
发表于 2002-5-5 21:14:00 | 显示全部楼层
这种方法简单...
GetSubEntity 方法
它可以直接取得图元或嵌套图元的信息,取得后你就可以随便对其进行读取或更改。
语法:
object.GetSubEntity Object, PickedPoint, TransMatrix, ContextData[, Prompt]
样例:
Sub Example_GetSubEntity()
    ' This example prompts the user to select on object on the screen with a mouse click,
    ' and returns some information about the selected object.
    Dim Object As Object
    Dim PickedPoint As Variant, TransMatrix As Variant, ContextData As Variant
    Dim HasContextData As String
    On Error GoTo NOT_ENTITY
TRYAGAIN:
    MsgBox "Use the mouse to click on an entity in the current drawing after dismissing this dialog box."
    ' Get information about selected object
    ThisDrawing.Utility.GetSubEntity Object, PickedPoint, TransMatrix, ContextData
    ' Process and display selected object properties
    HasContextData = IIf(VarType(ContextData) = vbEmpty, " does not ", " does ")
    MsgBox "The object you chose was an: " & TypeName(Object) & vbCrLf & _
            "Your point of selection was: " & PickedPoint(0) & ", " & _
                                              PickedPoint(1) & ", " & _
                                              PickedPoint(2) & vbCrLf & _
            "This object" & HasContextData & "have nested objects."
    Exit Sub
GMT+8, 2026-1-11 04:16 , Processed in 0.150415 second(s), 24 queries , Gzip On.
