查看: 1358|回复: 3
关于三维旋转的程序,有点问题,大家来帮我看看啊!!!
发表于 2006-5-31 13:42:00 | 显示全部楼层 |阅读模式
我生成一个圆环面域,想让它绕着Y轴旋转90度,程序如下,大家帮我改改啊
Sub Example_Rotate3D()
  Dim circle1(0) As AcadEntity
   Dim circle2(0) As AcadEntity
   Dim regionObj1 As Variant
   Dim regionObj2 As Variant
   Dim point1(0 To 2) As Double
   Dim radius1 As Double
   Dim radius2 As Double
   Dim solidObj As Acad3DSolid
   Dim polyObj As Acad3DPolyline
   radius1 = 15
   radius2 = 10
   point1(0) = 0
   point1(1) = -50
   point1(2) = 0
    '创建面域
   Set circle1(0) = ThisDrawing.ModelSpace.AddCircle(point1, radius1)
   Set circle2(0) = ThisDrawing.ModelSpace.AddCircle(point1, radius2)
   regionObj1 = ThisDrawing.ModelSpace.AddRegion(circle1)
   regionObj2 = ThisDrawing.ModelSpace.AddRegion(circle2)
   '布尔运算
   regionObj1(0).Boolean acSubtraction, regionObj2(0)
   '三维旋转
   Dim point2(0 To 2) As Double
   Dim point3(0 To 2) As Double
   Dim rotateAngle As Double
   rotateAngle = 90 * 3.141592 / 180#
   point2(0) = 0
   point2(1) = 0
   point2(2) = 0
   point3(0) = 0
   point3(1) = -50
   point3(2) = 0
   regionObj1.Rotate3D point2, point3, rotateAngle//这句有问题,说是"要求对象"
   ThisDrawing.Regen True
End Sub
[glow=255,red,2]文字[/glow]
发表于 2006-5-31 15:58:00 | 显示全部楼层
姐姐,怎么又是你啊,你的程序还有问题啊。。。。。
1,regionobj1是个数组,没有Rotate3D的属性,所以要选定数组里的一个对象才行
2。作为旋转轴的线段事先要创建好才行,不能凭空指定两点
所以把你这句regionObj1.Rotate3D point2, point3, rotateAngle 改成
ThisDrawing.ModelSpace.AddLine point2, point3
   regionObj1(0).Rotate3D point2, point3, rotateAngle
就行了!
 楼主| 发表于 2006-6-1 09:40:00 | 显示全部楼层
大哥,那我怎么样才能使最后只保留旋转后的面域呢,之前的面域和旋转轴都不要显示
发表于 2006-6-1 10:58:00 | 显示全部楼层
   Dim Line1 As AcadLine
   Set Line1 = ThisDrawing.ModelSpace.AddLine(point2, point3)
   circle1(0).Visible = False
   circle2(0).Visible = False
   Line1.Visible = False
更正你一下,旋转完面域后原来的面域位置就是两个圆存在,不是面域。。。。。
GMT+8, 2026-1-16 10:34 , Processed in 2.869631 second(s), 23 queries , Gzip On.
