楼主: SWAYWOOD
[求助]块说明和块DXF有关系吗?
发表于 2006-6-27 12:20:00 | 显示全部楼层
(entget
  (tblobjname
    "block"
    (cdr (assoc 2 (entget (car (entsel "\n点选匿名块: ")))))
 楼主| 发表于 2006-6-27 13:14:00 | 显示全部楼层
哦,原来INSERT和BLOCK间还能这样访问啊
发表于 2006-6-27 14:35:00 | 显示全部楼层
I don't understand why you uploaded a drawing B without an anonymous block. It depends on how you converted your block into an anonymous one. I used the Rename Method and the following code is still working well.
(CDR (ASSOC 4 (TBLSEARCH "BLOCK" (CDR (ASSOC 2 (ENTGET (CAR
(ENTSEL))))))))
 楼主| 发表于 2006-7-24 12:17:00 | 显示全部楼层
You are right sir,the anonymous block still has its name,so we can get the information we want directly.I DID not know this before.Thanks!
GMT+8, 2025-12-18 06:06 , Processed in 0.136250 second(s), 20 queries , Gzip On.
