楼主: wei209
画一条多义线每隔1米加一个0.5米的横短线怎么实现啊?
发表于 2007-4-9 09:00:00 | 显示全部楼层
先定义一个块,再用MEASURE命令.lsp也可以做,但计算要复杂点,对多义线,首先要求出每隔1.5米的所有点,然后分别求出该点的法线角度,也就可以达到目的要求了.
发表于 2007-4-9 10:18:00 | 显示全部楼层
(defun c:kjh ( / )
(setvar "osmode" 0)                           ;关闭捕捉
(command"_pline" (list 0 0) (list 100 0) "")  ;画长为100的水平线
(command"_pline" (list 0 0) (list 0 0.5) "")  ;画长为0.5的垂直线
(command "-array" (entlast) "" "r" 1 101 1 "");1行,101列,列距为1的矩阵
(setvar "osmode" 35)                          ;打开捕捉
发表于 2007-4-9 10:20:00 | 显示全部楼层
(defun c:kjh ( / )
发表于 2007-4-9 11:19:00 | 显示全部楼层
多义线只是水平的吗?只有一段吗?这有点太简单了
 楼主| 发表于 2007-4-9 16:49:00 | 显示全部楼层
"-array" 改为 "_array"
发表于 2007-4-10 21:45:00 | 显示全部楼层
;;; By Alvin Y. LIN
(defun C:test (/   interval   width initlen    oldOSMODE
        plObj   ent      startPoint endPoint   initPoint
        revp   len      interval num    cnt
        rotang   firstDeriv pt  stPoint    selPoint
  (setq interval 1000   ; 1m
 width 500   ; 0.5m
 initlen 0   ;????
  (setq oldOSMODE (getvar "OSMODE"))
  (command "ucs" "w")
  (setq plObj (vlax-ename->vla-object
  (car
    (setq ent (entsel "\nSelect an object: "))
  (if (member (vla-get-objectname plObj)
       '("AcDbPolyline"   "AcDbLine"     "AcDbSpline"
  "AcDbARC"   "AcDbCircle"     "AcDbEllipse"
      (setq selPoint (cadr ent))
      (setq startPoint (vlax-curve-getStartPoint plObj))
      (setq endPoint (vlax-curve-getEndPoint plObj))
      (if (> (distance selPoint startPoint)
      (distance selPoint endPoint)
 (setq stPoint endPoint
       revp    T
 (setq stPoint startPoint
       revp    nil
      (setvar "OSMODE" 0)
      (setq len (- (vlax-curve-getDistAtParam
       plObj
       (vlax-curve-getendparam plObj)
     initlen
      (setq num (1+ (fix (/ len interval))))
      (setq cnt 0)
      (command "undo" "BE")
      (while (<= cnt (1- num))
 (cond ((= revp nil)
        (setq pt (vlax-curve-getPointAtDist
     plObj
     (+ initlen (* interval cnt))
        (setq firstDeriv
        (vlax-curve-getFirstDeriv
   plObj
   (vlax-curve-getParamAtPoint plObj pt)
        (setq rotang (angle '(0 0 0) firstDeriv))
        (command "line"
   (polar pt (+ rotang (* 0.5 pi)) (* 0.5 width))
   (polar pt (- rotang (* 0.5 pi)) (* 0.5 width))
       ((= revp T)
     plObj
     (- len (* interval cnt))
        (setq firstDeriv
   plObj
        (command "line"
 )    ;cond
 (setq cnt (1+ cnt))
      )     ;while
      (command "undo" "E")
    )     ;progn
    (alert "\Invalid object Selected!")
  )     ;endif
  (vlax-release-object plObj)
  (command "ucs" "p")
  (setvar "OSMODE" oldOSMODE)
发表于 2007-4-11 09:23:00 | 显示全部楼层
可以改一下,即画即显示,加入比例变量,但怎样在多义线绘制中间能够绘制短线,就是说在命令行显示为:
指定下一点或 [圆弧(A)/闭合(C)/半宽(H)/长度(L)/放弃(U)/宽度(W)]:
的时候能运行程序.
我一时还没想到办法(可以用程序去模拟多义线绘制命令,但这样较复杂点),是否注册一个透明命令?
(defun C:test (/ scale  interval   width initlen    oldOSMODE
        plObj   ent  pt1 pt2    startPoint endPoint   initPoint
  (setq scale (getreal "\n请输入比例1:<1000>"))
  (if (not scale) (setq scale 1000))
  (setq interval scale   ; 1m
 width (* scale 0.5)  ; 0.5m
 initlen 0   ;????
  (setq cnt 0)
  (command "ucs" "w")
  (vl-load-com)
  (setq pt1 (getpoint "\n输入多义线起点"))
  (setq pt2 (getpoint pt1 "\n输入多义线顶点(下一点)"))
  (while pt2
    (command "_.pline" pt1 pt2 "")
    (if ent (progn (command "_.pedit" ent "j" (entlast) "" ""))) (setq ent (entlast))
  (setq plObj (vlax-ename->vla-object ent
;;;  (car
;;;    (setq ent (entsel "\nSelect an object: "))
       '("AcDbPolyline" "AcDb2dPolyline"  "AcDbLine"     "AcDbSpline"
;;;      (setq selPoint (cdr (assoc 10 (entget ent)))));(cadr ent))
;;;      (if (> (distance selPoint startPoint)
;;;      (distance selPoint endPoint)
;;; (setq stPoint endPoint
;;;       revp    T
       revp    nil
      (setvar "OSMODE" 0)
       plObj
     initlen
 (cond ((= revp nil)
     plObj
        (setq firstDeriv
   plObj
        (command "line"
       ((= revp T)
     plObj
        (setq firstDeriv
   plObj
        (command "line"
 )    ;cond
 (setq cnt (1+ cnt))
      )     ;while
    )     ;progn
  )     ;endif
    (setq pt1 pt2)
  (command "ucs" "p")
发表于 2007-4-26 11:31:00 | 显示全部楼层
楼上的,我运行了以后发现是以下这个样子哦!
在转弯的地方就不能在多段线上了!
发表于 2007-4-26 11:35:00 | 显示全部楼层
这里没有多段线模拟程序,也就是没有加入弧段的功能,要稍加修改方能实现
发表于 2007-4-28 13:50:00 | 显示全部楼层
问题是 难者不会,会者不难!
请楼上的帮忙一下哦!
GMT+8, 2025-12-18 16:41 , Processed in 0.204880 second(s), 20 queries , Gzip On.
