楼主: wujin
请陈老师或各位高手帮个忙编个程序(能实现在图低中批量代换图形的功能。)
 楼主| 发表于 2003-4-5 18:44:00 | 显示全部楼层
不太懂啊,能说一下怎么用吗,我不会编程呀。
发表于 2003-4-7 08:22:00 | 显示全部楼层
BLOCK名稱為"1","2","3"....指的是直徑
发表于 2003-4-7 10:50:00 | 显示全部楼层
圓孔統計表>>>
(defun C:SUM_CIRCLE
       (/ HOLDOSMODE HOLDZIN HOLDECHO HOLE_LIST #FF R1_LIST)
  (defun WRITE_LINE (/ LL)
    (setq #FF (polar #FF (/ pi 2.0) (* #H 1.5)))
    (command "_.line"
             (polar #FF pi (* #H 4.5))
             (polar #FF 0 (* #H 9))
    (command "_.ARRAY"
             (entlast)
             "R"
             (+ (length R1_LIST) 2)
             (* -2 #H)
    (command "_.line"
             (cdr (assoc 10 (entget (entlast))))
    (setq LL (entlast))
    (command "_.COPY" LL "" #FF (polar #FF 0 (* #H 9.5)))
    (command "_.COPY" LL "" #FF (polar #FF 0 (* #H 13.5)))
  (defun WRITE_TABLE (H_LIST / DATA #F)
    (if        (= #H NIL)
      (setq #H 5)
    (while (= #F NIL)
      (initget 1 " ")
      (setq #F (getpoint "\n表格左上角/字体高度<>: "))
      (if (= #F "")
          (setq
            #H (getreal (strcat "\n字体高度<" (rtos #H 2 0) ">: "))
          (setq #F NIL)
    (setq #FF #F)
    (command "_.text" "j" "C" #F #H "" "直径")
    (command "_.text"
             "j"
             "C"
             (polar #F 0 (* #H 7))
             #H
             "数量"
    (setq #F (polar #F (/ pi -2.0) (* #H 2)))
    (while (/= (setq DATA (car H_LIST)) NIL)
      (command "_.text"
               "j"
               "BR"
               (polar #F 0 (* #H 3.5))
               #H
               (strcat "%%c" (rtos (* (car DATA) 2.0) 2 2))
      (command "_.text"
               "j"
               "C"
               #H
               (rtos (cadr DATA))
      (setq H_LIST (cdr H_LIST))
  (defun MAKE_LIST (/ SS N R_LIST TMP)
    (if        (setq SS (ssget "X" '((0 . "CIRCLE"))))
        (setq N 0)
        (repeat        (sslength SS)
          (if (not (member
                     (setq TMP (cdr (assoc 40 (entget (ssname SS N)))))
                     R_LIST
            (setq R_LIST (append R_LIST (list TMP)))
          (setq N (1+ N))
    (setq N 0)
    (repeat (length R_LIST)
      (setq
        TMP (ssget "X"
                   (list (cons 0 "CIRCLE") (cons 40 (nth N R_LIST)))
      (setq
        R1_LIST        (append        R1_LIST
                        (list (list (nth N R_LIST) (sslength TMP)))
      (setq N (1+ N))
  (setq HOLDECHO (getvar "CMDECHO"))
  (setvar "CMDECHO" 0)
  (command "_.UNDO" "_GROUP")
  (setq HOLDOSMODE (getvar "OSMODE"))
  (setq HOLDZIN (getvar "DIMZIN"))
  (setvar "DIMZIN" 8)
  (setvar "OSMODE" 0)
  (MAKE_LIST)
  (WRITE_TABLE R1_LIST)
  (WRITE_LINE)
  (setvar "OSMODE" HOLDOSMODE)
  (setvar "DIMZIN" HOLDZIN)
  (command "_.UNDO" "_END")
  (setvar "CMDECHO" HOLDECHO)
 楼主| 发表于 2003-4-7 22:34:00 | 显示全部楼层
非常感谢,我在努力消化程序。
 楼主| 发表于 2003-4-8 21:47:00 | 显示全部楼层
多谢龙仔,我想再在旁边加一个条目该如何改程序呢。像这个(附效果图)
符号那一列只要留一列空间就行了,我可以自己画圆代换进去,然后再用块代换程序代换。或者龙大哥帮忙也搞个每种圆画在序号这一列上面,那就太好了。我想再在孔径一列后面再加一列冲针,内容和孔径里面的一样。这样不知道行不行哪。再帮我搞一下吧,谢谢大哥啦。本人太菜啦,看了程序不会改。
发表于 2003-4-9 17:02:00 | 显示全部楼层
如何改程序??太簡單,多看點書,我弄好了,但還是讓你自己做比較好!
 楼主| 发表于 2003-4-9 20:45:00 | 显示全部楼层
我晕倒,不是吧,龙仔,我手上没有书呀。我都是看的ACAD的帮助文件,那我自己改着试
我晕倒,不是吧,龙仔,我手上没有书呀。我都是看的ACAD的帮助文件,那我自己改着试一下。[br]
 楼主| 发表于 2003-4-10 01:01:00 | 显示全部楼层
我也搞定了,多谢龙大侠指导,帮我看看对不对,哪里还要改不。
;圓孔統計表>>>
(defun C:tjbok
    (command "_.line"
             (polar #FF 0 (* #H 14))
    (command "_.ARRAY"
             (entlast)
             "R"
             (* -2 #H)
    (command "_.line"
    (setq LL (entlast))
    (command "_.COPY" LL "" #FF (polar #FF 0 (* #H 4.3)))
    (command "_.COPY" LL "" #FF (polar #FF 0 (* #H 18.5)))
    (if        (= #H NIL)
      (setq #H 5)
    (while (= #F NIL)
      (initget 1 " ")
      (if (= #F "")
          (setq
          (setq #F NIL)
    (setq #FF #F)
    (command "_.text" "j" "C" #F #H "" "符号  孔径")
    (command "_.text"
             "j"
             "C"
             #H
             "冲针"
    (command "_.text"
             "j"
             "C"
             (polar #F 0 (* #H 12))
             #H
             "数量"
      (command "_.text"
               "j"
               "BR"
               #H
               (strcat "Φ" (rtos (* (car DATA) 2.0) 2 2))
      (command "_.text"
               "j"
               "C"
               #H
       (command "_.text"
               "j"
               "C"
               #H
               (rtos (cadr DATA))
      (command "_.circle"
               (polar #F 0 (* #H -3))
               (car DATA)
        (setq N 0)
          (if (not (member ;MEMBER搜索表R_LIST中是否包含图元为N的半径表达式,并从该表达式的第一次出现处返回表的其余部分
                     (setq TMP (cdr (assoc 40 (entget (ssname SS N)))));TMP为SS集中图元名为N的半径
                     R_LIST;如果R_LIST表中没有图元名为N的半径值。
            (setq R_LIST (append R_LIST (list TMP)));append将R_LIST和TMP表组合成一个表
          );将R_LIST表和N图元的半径值组合成一个R_LIST表(包含图中圆的所有半径)
          (setq N (1+ N))
    );遍历选择集SS中所有圆的半径值并组成一个表R_LIST
    (setq N 0)
    (repeat (length R_LIST);以表中所有的半径的总的数目做循环
      (setq
        TMP (ssget "X"
            );NTH为返回表中的第 n 个元素
      );设定选择集TMP为表R_LIST中第N个半径值的数量和
      (setq
      );设定表R1_LIST为所有的圆的每种圆的半径,数量
      (setq N (1+ N))
  (setvar "DIMZIN" 8)
  (setvar "OSMODE" 0)
  (MAKE_LIST)
  (WRITE_LINE)
发表于 2003-4-10 08:39:00 | 显示全部楼层
加個排序及序號!
(command "_.text"
               "j"
               "BR" ;應為"C"
               (polar #F 0 (* #H 3.5));修改位置2.5
               #H
      (command "_.text"
               "j"
               "C"
               #H
      (command "_.text"
               "j"
               "C"
               #H
               (rtos (cadr DATA))
      (command "_.circle"
               (car DATA)
               "" ;;取消
(MAKE_LIST)
  (WRITE_TABLE
    (vl-sort R1_LIST
             (function (lambda (E1 E2)
                         (< (car E1) (car E2))
  (WRITE_LINE)
 楼主| 发表于 2003-4-12 11:36:00 | 显示全部楼层
龙大虾,我弄好了。不知道能不能帮我帮我把这二个程序加在一起做呢
;圓孔統計表>>>
(defun C:tjbok
    (command "_.line"
             (polar #FF 0 (* #H 19))
    (command "_.ARRAY"
             (entlast)
             "R"
             (* -2 #H)
    (command "_.line"
    (setq LL (entlast))
    (command "_.COPY" LL "" #FF (polar #FF 0 (* #H 23.5)))
  (defun WRITE_TABLE (H_LIST / DATA #F zj)
    (if        (= #H NIL)
      (setq #H 5)
    (setq zj 0)
    (while (= #F NIL)
      (initget 1 " ")
      (if (= #F "")
          (setq
          (setq #F NIL)
    (setq #FF #F)
    (command "_.text" "j" "C" #F #H "" "符号  序号")
    (command "_.text"
             "j"
             "C"
             #H
             "孔径"
    (command "_.text"
             "j"
             "C"
             #H
             "冲针"
    (command "_.text"
             "j"
             "C"
             (polar #F 0 (* #H 17))
             #H
             "数量"
    (setq N 1)
      (command "_.text"
               "j"
               "c"
               #H
      (command "_.text"
               "j"
               "C"
               #H
      (command "_.text"
               "j"
               "C"
               #H
               (rtos (cadr DATA))
      (command "_.text"
               "j"
               "C"
               (polar #F 0 (* #H 2.5))
               #H
               (rtos N)
      (command "_.circle"
               (car DATA)
      (setq zj (+ zj (cadr DATA)))
      (setq N (1+ N))
    (setq #F (polar #F (/ pi -40.0) (* #H 2)))
    (command "_.text"
             "j"
             "C"
             (polar #F 0 (* #H 13.5))
             #H
             (strcat "总数=" (rtos zj))
        (setq N 0)
          (if (not (member
                     R_LIST
          (setq N (1+ N))
    (setq N 0)
      (setq
        TMP (ssget "X"
      (setq
      (setq N (1+ N))
  (setvar "DIMZIN" 8)
  (setvar "OSMODE" 0)
  (MAKE_LIST)
  (WRITE_TABLE
    (vl-sort R1_LIST
  (WRITE_LINE)
;以上是我改了后的圆孔统计表,不知道哪里还要修改不,帮我看看吧。我还改了个单个手工输入半径和块名的程序,这样我就可以把圆代换成块了。
我现在想把二个程序合起来用,不知道能不能实现哪,就是执行完圆孔统计表后自动执行代换程序,把图中所有有的圆孔变成块。下面的是我的单步执行程序。
;单个代换程序。
(defun c:dcb (/ ss CS1 count en p p3 ss1)
  (while (= ss NIL)
    (setq p3 0.5)
    (initget 1 )
    (setq p3 (getreal "\n输入要被代换圆的半径: "))
    (setq cs1 (getstring "\n输入代换的块名: "))
    (setq ss  (ssget "X"
                     (list
                       (cons 0 "circle")
                       (cons 40 p3)
          idx 0
  (command "undo" "BE")
  (setq count 0)
  (while (< count (sslength ss))
    (setq en (ssname ss count))
    (setq p (cdr (assoc 10 (entget en))))
    (entdel en)
    (command "-insert" cs1 p "" "" "")
    (setq count (1+ count))
  (setq        count nil
        en nil
        p nil
        ss nil
        cs1 nil
        p3 nil
GMT+8, 2025-12-18 21:34 , Processed in 0.145137 second(s), 19 queries , Gzip On.
