楼主: johnwang
如何将自己定义的命令放到菜单中
 楼主| 发表于 2006-11-18 16:29:00 | 显示全部楼层
The style of those two defined commands as follows:
(defun c:jc () ....)
(defun c:jb () ....)
Pls check and adv, thank you very much.
john
发表于 2006-11-18 17:44:00 | 显示全部楼层
Try this Partial menu file attached
usage:
Command: menuload
your may search help file ...
 楼主| 发表于 2006-11-19 12:03:00 | 显示全部楼层
Andyhon,
Thanks for your response, but I still can't find a good answer. those two defined commands as follows:
Pls give me more details, thanks a lot.
发表于 2006-11-19 12:51:00 | 显示全部楼层
发表于 2006-11-21 12:30:00 | 显示全部楼层
1、move or copy the file "finalnov.lsp" to searchpath of acad;
2、in the bottom of "acad.mnl",add line as follow:
   (load "finalnov")
3、in any popmenu group,for example "***POP2" of the file "acad.mnu",add line as follow:
   ID_aaaa1 [操作1]^C^Cjc
   ID_aaaa2 [操作2]^C^Cpb
4、in the acad command communicate area,enter command "menu",and select "acad.mnu",select several "ok"。
5、restart acad,your command will work!
whish you luck!
发表于 2006-11-21 12:58:00 | 显示全部楼层
你可以先用记事本编写一个abc.mnu文件,文件内容如下,编好后保存到CAD文件夹下的SUPPORT文件夹里,文件名为abc.mun,然后用记事本打开autocad.lsp文件在里面找到类似“(autoload "3darray" '("3darray"))”的句子然后在它下面重新起一行编写如下定义
(autoload "jc" '("jc"))
(autoload "jb" '("jb"))
保存后,将你的jc.lsp及jb.lsp拷贝到AUTOCAD 的SUPPORT文件夹下,启动AUTOCAD在“工具—自定义——“中将你的abc.mnu添加进去,应用保存,然后重新启动CAD就可以在CAD的下拉菜单中看到你的“自定义”菜单了就可以直接点击运行。
//      cljs.mnu for AutoCAD
***MENUGROUP=zdy
***POP1
              [自定义程序]
ID_jc         [框架材料计算]^C^C_jc
ID_jb         [盖板材料计算]^C^C_jb
 楼主| 发表于 2006-11-21 17:01:00 | 显示全部楼层
 thanks  liu_kunlun, thanks happyhxj and thanks  Andyhon
To tell you the truth, I'd resolved my problem by myself before I check your great responses to my question today.  I'd like to share my happiness with everybody. my detailed operation as follows.
1:依次点击 工具---自定义----编辑自定义文件----当前菜单.这时当前菜单文件自动打开.
2:确定自定义的命令所在位置,假设我们有两个自定义命令且打算把它们放在"工具"下拉菜单下.  为此,在打开的菜单文件下找到POP6. 在其中的第二行依次输入如下语句.
   ID_命令1     [命令1的文字表述]^C^C_命令1
   ID_命令2     [命令2的文字表述]^C^C_命令2
3. 保存并关闭菜单文件.
4.在命令行输入menu;
5.在对话框中选择修改后的当前菜单文件acad.mnc
6.点击打开,AUTOCAD 自动加载修改后菜单文件.自定义的命令就会出现在你想要它出现的地方.
发表于 2006-11-23 23:55:00 | 显示全部楼层
你可以自定义快捷按钮,包括按钮图形
在命令行中写入 ^c^c-jc 要在jc后面加一个空格
GMT+8, 2025-12-19 23:04 , Processed in 0.185389 second(s), 20 queries , Gzip On.
