楼主: hpy
[求助]恳请帮助:统计圆数量时如何去掉重复圆
发表于 2007-1-2 12:43:00 | 显示全部楼层
  1. (DEFUN DELETESAMEHOLES (SS_CIRCLE)
  2.   (SETQ ERASE_SUM 0
  3. I   0
  4. N   (SSLENGTH SS_CIRCLE)
  5. ZN   N
  6.   )
  7.   (WHILE (/= N 0)
  8.     (PROGN
  9.       (SETQ ED (ENTGET (SSNAME SS_CIRCLE I))
  10.      RAD (CDR (ASSOC '40 ED))
  11.      X (CADR (ASSOC 10 ED))
  12.      Y (CADDR (ASSOC 10 ED))
  13.      Z (LAST (ASSOC 10 ED))
  14.       )
  15.       (SETQ J (+ I 1))
  16.       (REPEAT (- (- ZN I) 1)
  17. (PROGN
  18.    (SETQ ENT  (SSNAME SS_CIRCLE J)
  19.   ED  (ENTGET ENT)
  20.   X_SAME  (CADR (ASSOC 10 ED))
  21.   Y_SAME  (CADDR (ASSOC 10 ED))
  22.   Z_SAME  (LAST (ASSOC 10 ED))
  23.   RAD_SAME (CDR (ASSOC '40 ED))
  24.    )
  25.    (IF (AND (EQUAL X_SAME X 0.00001)
  26.      (EQUAL Y_SAME Y 0.00001)
  27.      (EQUAL Z_SAME Z 0.00001)
  28.      (EQUAL RAD_SAME RAD 0.00001)
  29.        )
  30.      (PROGN
  31.        (SSDEL ENT SS_CIRCLE)
  32.        (COMMAND "ERASE" ENT "")
  33.        (SETQ N       (- N 1)
  34.       ERASE_SUM (1+ ERASE_SUM)
  35.        )
  36.      )
  37.      (SETQ J (+ J 1))
  38.    )
  39. )
  40.       )
  41.       (SETQ ZN (SSLENGTH SS_CIRCLE))
  42.       (IF (< I (- (SSLENGTH SS_CIRCLE) 1))
  43. (SETQ I (1+ I))
  44.       )
  45.       (SETQ N (- N 1))
  46.     )
  47.   )
  48.   (IF (/= ERASE_SUM 0)
  49.     (PROGN
  50.       (REDRAW)
  51.       (ALERT (STRCAT "\n 有 "
  52.        (RTOS ERASE_SUM 2 0)
  53.        " 个重复的孔将被删除!!! "
  54.       )
  55.       )
  56.     )
  57.   )
  58.   SS_CIRCLE
  59. )
复制代码
这是以有写的一程序里面用到的,可以控制精度.
因为两圆重叠时,不一定刚好是同心或等半径.
发表于 2007-1-3 23:45:00 | 显示全部楼层
  1. (defun c:tt (/ ss i e ent cpt r pts)
  2.   (setq ss(ssget '((0 . "CIRCLE")))
  3. fz (getdist "\n 圆心&半径误差(误差值内按1个计算):")
  4.         i -1)
  5.   (while(setq e(ssname ss(setq i(1+ i))))
  6.    (setq ent (entget e)
  7.   cpt (cdr(assoc 10 ent))
  8.   r   (cdr(assoc 40 ent)))
  9.    (if (not(member 'T (mapcar '(lambda(x)(and(equal cpt (car x) fz)(equal r (cadr x) fz)))pts)))
  10.    (setq pts (cons (list cpt r) pts))
  11.    )
  12.    ) (length pts)
  13. )
发表于 2007-10-17 17:41:00 | 显示全部楼层
楼主,相关命令是什么啊?我不是很清楚啊,谢谢!
liguofeng3909@126.com
发表于 2011-6-9 11:19:36 | 显示全部楼层
回复 无痕 的帖子
简洁.实用.明了.很好
发表于 2011-6-10 20:28:07 | 显示全部楼层
http://ljttjl.ys168.com 2009-2试用程序及演示  20091111删除完全重叠图元对象 目录下载此程序
以下为此程序演示:
发表于 2024-12-2 09:11:27 | 显示全部楼层
phoenixdjq 发表于 2006-12-29 20:47
给你一个网上下载的删除重线的程序,谁做的我忘了你可以先把多余的圆删除,然后再计算,就可以了&nbsp;
好用,谢谢大佬分享,学习了。居然是18年前的东西,太强了
GMT+8, 2026-1-13 08:47 , Processed in 0.178498 second(s), 21 queries , Gzip On.
