楼主: tcsl9621
LISP调用DLL文件生成随机数
发表于 2007-1-18 14:45:00 | 显示全部楼层
lisp调用dll,很好
发表于 2007-1-18 17:26:00 | 显示全部楼层
有个问题:
希望能调用DLL,生成一个随机排列数组的函数。
例如有一个数组,元素可能有上百万个,现在要对这个数组的元素随机排列,就像洗牌那样。生成这样一个函数,最后供Vlisp调用。算法上最好能对空间和时间都有照顾!
以前曾经考虑直接用lisp,但没有成功。下面我引用一段VB代码,只不过是一个特例:
  Dim   a(3)   As   Integer
  Private   Sub   Form_Load()
          a(0)   =   3
          a(1)   =   6
          a(2)   =   8
          a(3)   =   9
  End   Sub
  Private   Sub   Command1_Click()
          Randomize
          Dim   tmp
          Dim   tmp_index   As   Integer
          Dim   Lb   As   Integer,   Ub   As   Integer
          Lb   =   LBound(a)
          Ub   =   UBound(a)
          Dim   i   As   Integer
          For   i   =   Lb   To   Ub
                  tmp_index   =   Int((Ub   -   Lb   +   1)   *   Rnd   +   Lb)
                  tmp   =   a(i)
                  a(i)   =   a(tmp_index)
                  a(tmp_index)   =   tmp
          Next
          For   i   =   Lb   To   Ub
                  Debug.Print   "a("   &   i   &   ")="   &   a(i)
          Next
  End   Sub
发表于 2007-1-19 01:28:00 | 显示全部楼层
  1. (defun rnd(rMin rMax / e)
  2.    (vla-eval (vlax-get-acad-object) "Randomize : ThisDrawing.setVariable "USERR5" ,CDbl((Rnd))" )
  3.    (setq e (+ rMin (* (getvar "userr5")(- rMax rMin))) )
  4.    (if (= 'INT (type rmin)(type rmax))
  5.      (fix e)
  6.      e
  7.    )
  8. )
  9. (defun rndsort (lst / len a lst2)
  10.   (repeat (setq len (length lst))
  11.     (while (member (setq a (rnd 0 len)) lst2));;这步算法可优化
  12.     (setq lst2 (cons a lst2))
  13.   )
  14.   (mapcar '(lambda (x) (nth x lst)) lst2)
  15. )
  1. ;; 测试:
  2. (defun c:tt (/ lst)
  3.   (setq lst '(-562  969   777 -97   -389  -827  -197 -850  -265
  4.        -933  942   444 354   629   -95   612 909   -852
  5.        -267  868   428 127   -324  845   -834 -203  962
  6.        142   561   721 305   347   314   -925 -154  -845
  7.        -506  575   688 427   -545  -752  -495 121   -886
  8.        -691  364   -758 193   36    324   -762 174   -64
  9.        -182  868   698 483   454   -167  456 984   -628
  10.        812   861   -901 707   897   -745  226 107   943
  11.        -798  83   -18 -583  327   589   -703 -154  -461
  12.        263   -374  449 -62   -962  -567  -764 -860  -967
  13.        -139  399   -271 772   -157  573   -613 -964  827
  14.        554
  15.       )
  16.   )
  17.   (repeat 10
  18.     (print (rndsort lst))
  19.   )
  20. )
  5.      (fix e)
  6.      e
  7.    )
  8. )
  11.     (while (and
  12.        (member (setq a (rnd 0 len)) lst2);;这步算法可优化
  13.        (or(= 0 a)(member (setq a (1- a)) lst2))
  14.        (or(= a (1- len))(member (setq a (1+ a)) lst2))
  15.     )
  16.       )
  17.     (setq lst2 (cons a lst2))
  18.   )
  19.   (mapcar '(lambda (x) (nth x lst)) lst2)
  20. )
  1. ;; 测试:
  3.   (setq lst '(-562  969   777 -97   -389  -827  -197 -850  -265  -933  942   444 354   629   -95   612 909   -852
  4.        -267  868   428 127   -324  845   -834 -203  962  142   561   721 305   347   314   -925 -154  -845
  5.        -506  575   688 427   -545  -752  -495 121   -886  -691  364   -758 193   36    324   -762 174   -64
  6.        -182  868   698 483   454   -167  456 984   -628  812   861   -901 707   897   -745  226 107   943
  7.        -798  83   -18 -583  327   589   -703 -154  -461  263   -374  449 -62   -962  -567  -764 -860  -967
  8.        -139  399   -271 772   -157  573   -613 -964  827  554))
  9.   (repeat 10
  10.     (print (rndsort lst))
  11.   )
  12. )
发表于 2007-1-19 03:00:00 | 显示全部楼层
这个快一点
  1. (defun rndsort3 (lst / A b I LEN LEN2 LST2 LST3)
  2.   ;;构造0~(表长-1)整数序列.
  3.   (setq len (length lst))
  4.   (repeat (setq b len)
  5.     (setq lst2 (cons (setq b (1- b)) lst2))
  6.   )
  7.   (repeat len
  8.     (setq i    (rnd 0 (length lst2))
  9.    a    (nth i lst2)
  10.           lst3 (cons a lst3)
  11.    lst2 (vl-remove a lst2))
  12.   )
  13.   (mapcar '(lambda (x) (nth x lst)) lst3)
  14. )
参与人数 1威望 +1 明经币 +2 金钱 +20 贡献 +5 激情 +5 收起 理由
mccad + 1 + 2 + 20 + 5 + 5 【精华】好程序
 楼主| 发表于 2007-1-19 20:53:00 | 显示全部楼层
这个帖子抛了块砖,没想到引来了一堆玉。真是不错。这个帖子就是给大家介绍LISP调用DLL文件。这只是个简单引用。但可以编些其他VB函数来供LISP调用。
发表于 2007-1-21 18:02:00 | 显示全部楼层
试试我这个:
  1. (defun rndsortlst (lst / rndlst)
  2.   (repeat (length lst)
  3.     (setq rndlst (cons (rnd) rndlst))
  4.   )
  5.   (setq rndlst (vl-sort-i rndlst '>))
  6.   (mapcar '(lambda (a) (nth a lst)) rndlst)
  7. )
快吗?
发表于 2007-1-22 12:31:00 | 显示全部楼层
16樓(rnd)???
調用dll還會快嗎?
;;BY LUCAS  (排1千個)
(defun RND_LAI (/ STR)
  (setq STR (rtos (getvar "cputicks") 2 0))
  (/ (atoi (substr STR (- (strlen STR) 3))) 10000.0)
(defun RNDSORT5 (LEN / A B I LST2 LST3)
  (repeat (setq B LEN)
    (setq LST2 (cons (setq B (1- B)) LST2))
  (repeat LEN
    (setq I    (fix (* LEN (RND_LAI)))
   LEN  (1- LEN)
   A    (nth I LST2)
   LST3 (cons A LST3)
   LST2 (vl-remove A LST2)
  LST3
(defun C:TT (/ N LST)
  (setq N   0
   LST NIL
  (repeat 1000
    (setq LST (cons (setq N (1+ N)) LST))
  (setq STIME (getvar "date"))
  (setq LST (mapcar '(lambda (X) (nth X LST)) (RNDSORT5 (length LST))))
  (setq ETIME (getvar "date"))
  (prompt
    (strcat
      "\n程式共耗用時間: "
      (rtos (* 86400.0 (- (- ETIME STIME) (fix (- ETIME STIME))))
     2
     3
      "秒\n"
  LST
发表于 2007-1-22 12:50:00 | 显示全部楼层
to fsxm:
的确比无痕的快,谢谢fsxm!但还没明白怎么回事,不知能否把那个rnd函数的源码贴上来呢?
to 龙版主:
从你这儿又学了一招!有一个问题是,如果利用cputicks来作随机数,是不是有一定局限性,譬如受浮点影响呢?
发表于 2007-1-23 00:02:00 | 显示全部楼层
  1. (defun C:TT2 (/ ETIME LST N STIME X)
  2.   (setq N   0
  3. LST NIL
  4.   )
  5.   (repeat 10000
  6.     (setq LST (cons (setq N (1+ N)) LST))
  7.   )
  8.   (setq STIME (getvar "date"))
  9.   (setq LST (mapcar '(lambda (X) (nth X LST)) (rndsi (length lst))))
  10.   (setq ETIME (getvar "date"))
  11.   (prompt
  12.     (strcat
  13.       "\n程式共耗用時間: "
  14.       (rtos (* 86400.0 (- (- ETIME STIME) (fix (- ETIME STIME))))
  15.      2
  16.      3
  17.       )
  18.       "秒\n"
  19.     )
  20.   )
  21.   LST
  22. )
程式共耗用時間: 0.469秒
程序也用了cputicks
rndsi和tt2已经打包,下载解压后调入cad可直接运行tt2
GMT+8, 2025-12-14 05:09 , Processed in 0.162391 second(s), 19 queries , Gzip On.
