楼主: 烟雨.江南
[求助]怎么用VBA实现选择集中的实体处于被选中状态?
发表于 2011-11-10 19:45:38 | 显示全部楼层
我也有同样疑问
发表于 2011-11-10 20:02:02 | 显示全部楼层
我也想知道啊,请高手指点
发表于 2011-11-13 12:11:10 | 显示全部楼层
使用VLAX类结合VBA可以实现夹点显示。
VLAX类代码:
  1. ' VLAX.CLS v2.0 (Last updated 8/1/2003)
  2. ' Copyright 1999-2001 by Frank Oquendo
  3. '
  4. ' 该程序由明经通道修改支持2004版本
  5. ' http://www.mjtd.com
  6. '
  7. ' Permission to use, copy, modify, and distribute this software
  8. ' for any purpose and without fee is hereby granted, provided
  9. ' that the above copyright notice appears in all copies and
  10. ' that both that copyright notice and the limited warranty and
  11. ' restricted rights notice below appear in all supporting
  12. ' documentation.
  13. '
  14. ' FRANK OQUENDO (THE AUTHOR) PROVIDES THIS PROGRAM "AS IS" AND WITH
  15. ' ALL FAULTS. THE AUTHOR SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY
  16. ' OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE.  THE AUTHOR
  17. ' DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
  18. ' UNINTERRUPTED OR ERROR FREE.
  19. '
  20. ' Use, duplication, or disclosure by the U.S. Government is subject to
  21. ' restrictions set forth in FAR 52.227-19 (Commercial Computer
  22. ' Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
  23. ' (Rights in Technical Data and Computer Software), as applicable.
  24. '
  25. ' VLAX.cls allows developers to evaluate AutoLISP expressions from
  26. ' Visual Basic or VBA
  27. '
  28. ' Notes:
  29. ' All code for this class module is publicly available througout various posts
  30. ' at news://discussion.autodesk.com/autodesk.autocad.customization.vba. I do not
  31. ' claim copyright or authorship on code presented in these posts, only on this
  32. ' compilation of that code. In addition, a great big "Thank you!" to Cyrille Fauvel
  33. ' demonstrating the use of the VisualLISP ActiveX Module.
  34. '
  35. ' Dependencies:
  36. ' Use of this class module requires the following application:
  37. ' 1. VisualLISP
  38. Private VL As Object
  39. Private VLF As Object
  40. Private Sub Class_Initialize()
  41.     Dim AcadVersion As Integer
  42.     With ThisDrawing.Application
  43.         AcadVersion = Val(Left(.Version, 2))
  44.         '根据AutoCAD的版本判断使用的VL库类型
  45.         Select Case AcadVersion
  46.             Case Is = 15
  47.                 Set VL = .GetInterfaceObject("VL.Application.1")
  48.             Case Is >= 16
  49.                 Set VL = .GetInterfaceObject("VL.Application.16")
  50.         End Select
  51.     End With
  52.     Set VLF = VL.ActiveDocument.Functions
  53. End Sub
  54. Public Function EvalLispExpression(lispStatement As String)
  55.     '根据LISP表达式调用函数
  56.     Dim sym As Object, ret As Object, retVal
  57.     Set sym = VLF.Item("read").funcall(lispStatement)
  58.     On Error Resume Next
  59.     retVal = VLF.Item("eval").funcall(sym)
  60.     If Err Then
  61.         EvalLispExpression = ""
  62.     Else
  63.         EvalLispExpression = retVal
  64.     End If
  65.     On Error GoTo 0
  66. End Function
  67. Public Sub SetLispSymbol(symbolName As String, value)
  68.     Dim sym As Object, ret, symValue
  69.     symValue = value
  70.     Set sym = VLF.Item("read").funcall(symbolName)
  71.     ret = VLF.Item("set").funcall(sym, symValue)
  72.     EvalLispExpression "(defun translate-variant (data) (cond ((= (type data) 'list) (mapcar 'translate-variant data)) ((= (type data) 'variant) (translate-variant (vlax-variant-value data))) ((= (type data) 'safearray) (mapcar 'translate-variant (vlax-safearray->list data))) (t data)))"
  73.     EvalLispExpression "(setq " & symbolName & "(translate-variant " & symbolName & "))"
  74.     EvalLispExpression "(setq translate-variant nil)"
  75. End Sub
  76. Public Function GetLispSymbol(symbolName As String)
  77.     Dim sym As Object, ret, symValue
  78.     symValue = value
  79.     Set sym = VLF.Item("read").funcall(symbolName)
  80.     GetLispSymbol = VLF.Item("eval").funcall(sym)
  81. End Function
  82. Public Function GetLispList(symbolName As String) As Variant
  83.     Dim sym As Object, list As Object
  84.     Dim Count, elements(), i As Long
  85.     Set sym = VLF.Item("read").funcall(symbolName)
  86.     Set list = VLF.Item("eval").funcall(sym)
  87.     Count = VLF.Item("length").funcall(list)
  88.     ReDim elements(0 To Count - 1) As Variant
  89.     For i = 0 To Count - 1
  90.         elements(i) = VLF.Item("nth").funcall(i, list)
  91.     Next
  92.     GetLispList = elements
  93. End Function
  94. Public Sub NullifySymbol(ParamArray symbolName())
  95.     Dim i As Integer
  96.     For i = LBound(symbolName) To UBound(symbolName)
  97.         EvalLispExpression "(setq " & CStr(symbolName(i)) & " nil)"
  98.     Next
  99. End Sub
  100. Private Sub Class_Terminate()
  101.     '类析构时,释放内存
  102.     Set VLF = Nothing
  103.     Set VL = Nothing
  104. End Sub
以下为测试代码:
  1. '使用直线选择集测试
  2. Sub ShowSelectLineCrips()
  3.     Dim ss As AcadSelectionSet
  4.     Dim objLine As AcadLine
  5.     Dim fType(0 To 0) As Integer
  6.     Dim fData(0 To 0) As Variant
  7.     Dim AutoSelect As Boolean
  8.     'AutoSelect = True
  9.     On Error Resume Next
  10.     ThisDrawing.SelectionSets("SelectText").Delete
  11.     Set ss = ThisDrawing.SelectionSets.Add("SelectText")
  12.     On Error GoTo 0
  13.     On Error GoTo ErrHandle
  14.     '创建过滤机制
  15.     fType(0) = 0: fData(0) = "LINE"         '直线
  16.     '选择符合条件的所有图元
  17.     If AutoSelect Then
  18.         '自动选择方式
  19.         ss.Select acSelectionSetAll, , , fType, fData
  20.     Else
  21.         '提示用户选择
  22.         ss.SelectOnScreen fType, fData
  23.     End If
  24.     If ss.Count = 0 Then Exit Sub
  25.     '显示夹点
  26.     ShowSelectionSetCrips ss
  27.     '删除数组
  28.     Erase fType: Erase fData
  29.     '删除选择集
  30.     ss.Clear: ss.Delete
  31.     Set ss = Nothing
  32.     Set objLine = Nothing
  33.     Exit Sub
  34. ErrHandle:
  35.     MsgBox Err.Description, vbCritical, "产生了以下错误:"
  36.     Err.Clear
  37. End Sub
  38. '显示选择集中对象的夹点
  39. Public Sub ShowSelectionSetCrips(ByRef ss As AcadSelectionSet)
  40.     Dim LispCode As New VLAX
  41.     Dim objEnt As AcadEntity
  42.     With LispCode
  43.         .EvalLispExpression "(setq ss (ssadd))"
  44.         For Each objEnt In ss
  45.             .EvalLispExpression "(ssadd " & _
  46.                                 "(handent " & Chr(34) & _
  47.                                 objEnt.Handle & Chr(34) & ")" & _
  48.                                 "ss" & _
  49.                                 ")"
  50.         Next
  51.         .EvalLispExpression "(sssetfirst nil ss)"
  52.         .EvalLispExpression "(setq ss nil)"
  53.     End With
  54.     Set LispCode = Nothing
  55.     'MsgBox "您选择了" & ThisDrawing.PickfirstSelectionSet.Count & "个对象"
  56. End Sub
注:以上代码在AutoCAD2004中调试通过。
发表于 2011-11-17 20:26:24 | 显示全部楼层
这个问题我也找了好久都没找到答案,试下上面的方法好用不!
这个方法不是很稳定 ,也很麻烦,最好的办法我觉得还是选择完成后,发送命令到CAD,代码:Thsidrawing.SendCommand "(sssetfirst nil (ssget ""P"")) "  发表于 2018-5-21 16:14
发表于 2011-12-12 21:01:32 | 显示全部楼层
谢谢 wylong 了,VBA也可以实现夹点显示了。
发表于 2011-12-15 16:46:45 | 显示全部楼层
我也试了为什么提示:Dim LispCode As New VLAX   用户类型未定义,怎么办?
发表于 2012-12-5 15:24:15 | 显示全部楼层
太好用了,谢谢!
发表于 2012-12-7 00:39:47 | 显示全部楼层
还是LISP省事,VLAX一大堆代码,看着都头晕
发表于 2013-1-13 19:24:48 | 显示全部楼层
新建一个类模块,感谢上面的提供,的确比LISp好,这样可以按空格重复执行
发表于 2013-5-14 23:02:48 | 显示全部楼层
VLAX   也是一种方法 顶起来。
GMT+8, 2026-1-19 09:12 , Processed in 0.188765 second(s), 21 queries , Gzip On.
