楼主: tangsong33
[原创]不要错过机会哦,自动查询尺寸公差标注
发表于 2011-3-22 00:54:56 | 显示全部楼层
提供一个思路,纯属抛砖引玉。
读取到标注的尺寸后利用COND函数进行处理,比如H7啊,g6啊,公差自动标注上去就行了。
程序未深究, 可能有不当之处,请大家指出。
  1. (DEFUN C:KH7 (/)
  2.   (tolerance)
  3.   (cond ((and (> tol_num 0) (<= tol_num 3))
  4.          (tole2 "0.01" "0" tol_nam))
  5.         ((and (> tol_num 3) (<= tol_num 6))
  6.          (tole2 "0.012" "0" tol_nam))
  7.         ((and (> tol_num 6) (<= tol_num 10))
  8.          (tole2 "0.015" "0" tol_nam))
  9.         ((and (> tol_num 10) (<= tol_num 18))
  10.          (tole2 "0.018" "0" tol_nam))
  11.         ((and (> tol_num 18) (<= tol_num 30))
  12.          (tole2 "0.021" "0" tol_nam))
  13.         ((and (> tol_num 30) (<= tol_num 50))
  14.          (tole2 "0.025" "0" tol_nam))
  15.         ((and (> tol_num 50) (<= tol_num 80))
  16.          (tole2 "0.030" "0" tol_nam))
  17.         ((and (> tol_num 80) (<= tol_num 120))
  18.          (tole2 "0.035" "0" tol_nam))
  19.         ((and (> tol_num 120) (<= tol_num 180))
  20.          (tole2 "0.040" "0" tol_nam))
  21.         ((and (> tol_num 180) (<= tol_num 250))
  22.          (tole2 "0.046" "0" tol_nam))
  23.         ((and (> tol_num 250) (<= tol_num 315))
  24.          (tole2 "0.052" "0" tol_nam))
  25.         ((and (> tol_num 315) (<= tol_num 400))
  26.          (tole2 "0.057" "0" tol_nam))
  27.         ((and (> tol_num 400) (<= tol_num 500))
  28.          (tole2 "0.063" "0" tol_nam))
  29.         ((> tol_num 500)
  30.          (alert "\nRange out!"))
  31.   ) ;end of cond
  32.   (princ)
  33. )
  34. (DEFUN tolerance (/ tol vla-obj la)
  35.   (if (not (setq tol (ssget "_i" '((0 . "DIMENSION")))))
  36.     (setq tol_nam (car (entsel "\nSelect a Dimension:")))
  37.     (setq tol_nam (ssname tol 0))
  38.   ) ;end of if
  39.   (if tol_nam
  40.     (progn
  41.       (setq la (cdr (assoc 8 (entget tol_nam))))
  42.       (setvar "cmdecho" 0)
  43.       (command "layer" "u" la "")
  44.     ) ;end of progn
  45.     (progn
  46.       (setvar "cmdecho" 1)
  47.       (vl-exit-with-error (alert "\nNo selection!"))
  48.     ) ;end of progn
  49.   ) ;end of if
  50.   (vl-load-com)
  51.   (setq vla-obj (vlax-ename->vla-object
  52.                   tol_nam
  53.                 ) ;end of vlax-ename->vla-object
  54.         tol_num (vla-get-Measurement vla-obj)
  55.   ) ;end of setq
  56.   (setvar "cmdecho" 1)
  57. )
发表于 2011-3-22 22:41:54 | 显示全部楼层
学习了。。。。
GMT+8, 2025-12-17 09:06 , Processed in 0.154123 second(s), 19 queries , Gzip On.
