楼主: c3a139
[求助]能否获得想要的数据
发表于 2007-6-18 16:45:00 | 显示全部楼层
这样试试:
  1. (DEFUN C:READATA ()
  2. (SETQ NM (IF NM NM ""))
  3. (IF (SETQ NM (GETFILED "Select Data File :" NM "*" 4)) (PROGN
  4.   (SETQ FP (OPEN NM "r"))
  5.   (SETQ DATALIST (LIST))
  6.   (SETQ A (READ-LINE FP))
  7.   (SETQ B (READ-LINE FP))
  8.   (WHILE (SETQ C (READ-LINE FP))
  9.    (COND
  10.     ((= (STRCASE C nil) "Z")
  11.      (SETQ DATALIST (APPEND DATALIST (LIST C)))
  12.      (SETQ DATALIST (APPEND DATALIST (IF (WCMATCH B ",") (LIST B) (LIST A B))))
  13.     )
  14.     ((= (STRCASE C nil) "Y")
  15.      (SETQ DATALIST (APPEND DATALIST (LIST C B)))
  16.     )
  17.    )
  18.    (SETQ A B B C)
  19.   )
  20.   (CLOSE FP)
  21. ))
  22. (IF (SETQ NM1 (GETFILED "Select File Name to Write :" NM1 "*" 4)) (PROGN
  23.   (SETQ I -1)
  24.   (SETQ FP (OPEN NM1 "w"))
  25.   (REPEAT (LENGTH DATALIST)
  26.    (PRINC (NTH (SETQ I (1+ I)) DATALIST) FP) (PRINC "\n" FP)
  27.   )
  28.   (CLOSE FP)
  29. ))
  30. (PRINC)
  31. )
复制代码
 楼主| 发表于 2007-6-19 11:49:00 | 显示全部楼层
ZZXXQQ发表于2007-6-18 13:26:00z前面是不是取两行数据?
这是个文本文件,我想读出我需要的数据,能否获取Z的最后一行和Y的最后一行,但
y
37.2,-2.8
318812.7
z
这也不好处理,上面的是y坐标,下面的是里程.
 楼主| 发表于 2007-6-21 17:27:00 | 显示全部楼层
zzxxqq版主,程序试了一下,不能运行,略修改了一下, cond...(T nil)...
(IF
  (SETQ NM1 (GETFILED
  "Select File Name to Write :" "" "*"
  1))
可以运行了,但结果不对,且程序中没有把里程(318812.7)同坐标(37.2,-2.8)区分开,如果在写入文件时在里程前加LC,即(LC 318812.7)是最好的,我现在传个文本文件
发表于 2007-6-21 20:35:00 | 显示全部楼层
根据要求改了改,可能写入的前后顺序不对。
  3.   (IF (SETQ NM (GETFILED "Select Data File :" NM "txt" 4)) (PROGN
  9.     (COND
  12.       (SETQ DATALIST (APPEND DATALIST (IF (WCMATCH B ",") (LIST B) (LIST A (STRCAT "LC " B)))))
  13.      )
  16.      )
  17.     )
  18.     (SETQ A B B C)
  19.    )
  20.    (CLOSE FP)
  21.   ))
  22.   (SETQ NM1 (IF NM1 NM1 ""))
  23.   (IF (SETQ NM1 (GETFILED "Select File Name to Write :" NM1 "txt" 9)) (PROGN
  24.    (SETQ I -1)
  25.    (SETQ FP (OPEN NM1 "w"))
  26.    (REPEAT (LENGTH DATALIST)
  27.     (PRINC (NTH (SETQ I (1+ I)) DATALIST) FP) (PRINC "\n" FP)
  28.    )
  29.    (CLOSE FP)
  30.   ))
  31.   (PRINC)
  32. )
复制代码
发表于 2007-6-22 08:00:00 | 显示全部楼层
怎麼看怎麼沒有規律,不好寫
 楼主| 发表于 2007-6-22 11:16:00 | 显示全部楼层
是写入的顺序不对
原数据
0,1
245400
z
35.3,-1.3
y
35.1,1
245450
z
34.9,-1.4
y
36.4,0.8
245500
z
25,-0.4
36.2,-0.6
y
35.7,1
245550
z
24.8,-0.5
36.1,-0.6
y
37.2,0.4
读写后数据
z
0,1
LC 245400
y
35.3,-1.3
z
35.1,1
LC 245450
y
34.9,-1.4
z
36.4,0.8
LC 245500
y
36.2,-0.6
z
35.7,1
LC 245550
y
36.1,-0.6
z
37.2,0.4
发表于 2007-6-22 11:23:00 | 显示全部楼层
你要什么顺序?
 楼主| 发表于 2007-6-25 12:23:00 | 显示全部楼层
与原数据的顺序一样,只是去掉了不需要的数据
0,1
245400
z
35.3,-1.3
y
35.1,1
245450
z
34.9,-1.4
y
36.4,0.8
245500
发表于 2007-6-25 13:15:00 | 显示全部楼层
  9.    (COND
  11.      (SETQ DATALIST (APPEND DATALIST (IF (WCMATCH B ",") (LIST B) (LIST A (STRCAT "LC " B)))))
  12.      (SETQ DATALIST (APPEND DATALIST (LIST C)))
  13.     )
  15.      (SETQ DATALIST (APPEND DATALIST (LIST B C)))
  16.     )
  17.    )
  18.    (SETQ A B B C)
  19.   )
  20.   (CLOSE FP)
  21. ))
  23.   (SETQ I -1)
  27.   )
  28.   (CLOSE FP)
  29. ))
  30. (PRINC)
  31. )
复制代码
 楼主| 发表于 2007-6-25 18:13:00 | 显示全部楼层
楼上的程序最后一个Y值无法写出,补了一句
(cond
  ((= (STRCASE C nil) "END")
即可写出了,在此再次感谢ZZXXQQ版主的热心帮助。
GMT+8, 2025-12-17 21:20 , Processed in 0.176168 second(s), 20 queries , Gzip On.
