查看: 1604|回复: 1
一段代码,请各位高手帮忙看看,错误提示缺少对象
发表于 2007-7-25 17:07:00 | 显示全部楼层 |阅读模式
代码如下:
Sub ppcolor()
'color select dialog
Dim ppentity As AcadEntity
Dim ppset As AcadSelectionSet
Set ppset = ThisDrawing.SelectionSets.Add("mmmm")
ppset.SelectOnScreen
ppset.Delete
Set ppset = Nothing
Dim xxx1 As Integer
xxx1 = ThisDrawing.Utility.GetInteger("输入需要改变实体颜色的序号:")
Dim gggppp As Double
If xxx1 = 1 Then
gggppp = acRed
ElseIf xxx1 = 2 Then
gggppp = acBlue
Else
gggppp = acCyan
End If
For Each ppentity In ppset
ppentity.color = gggppp
Next ppentity
End Sub
 楼主| 发表于 2007-7-25 17:45:00 | 显示全部楼层
问题自己已解决,把ppset.Delete选择集放到前面去了,一del,后面就完玩了,调试了很多,不过可能对大家有帮助,这样
大家就不会犯我的同样的错误了,
GMT+8, 2026-1-17 04:49 , Processed in 0.145599 second(s), 23 queries , Gzip On.
