查看: 1767|回复: 1
vba的一个多段线绘制问题
发表于 2007-8-1 15:08:00 | 显示全部楼层 |阅读模式
我用vba 编了一个程序,输入自变量范围绘制多段线,有些自变量能行有的就不行了弹出下列错误.说是 安全数组太少 或元素数目不是3的倍数,有那位高手知道怎么回事请指教。最好能给我讲讲解决的办法,我也很想和大家叫个朋友qq113080248
发表于 2007-8-1 15:43:00 | 显示全部楼层
区分两种多段线LightWeightPolyline和Polyline。详见AutoCAD ActiveX and VBA Reference
Sub Example_AddLightWeightPolyline()
    ' This example creates a lightweight polyline in model space.
    Dim plineObj As AcadLWPolyline
    Dim points(0 To 9) As Double
    ' Define the 2D polyline points
    points(0) = 1: points(1) = 1
    points(2) = 1: points(3) = 2
    points(4) = 2: points(5) = 2
    points(6) = 3: points(7) = 2
    points(8) = 4: points(9) = 4
    ' Create a lightweight Polyline object in model space
    Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
    ZoomAll
End Sub
Sub Example_AddPolyline()
    ' This example creates a polyline in model space.
    Dim plineObj As AcadPolyline
    Dim points(0 To 14) As Double
    points(0) = 1: points(1) = 1: points(2) = 0
    points(3) = 1: points(4) = 2: points(5) = 0
    points(6) = 2: points(7) = 2: points(8) = 0
    points(9) = 3: points(10) = 2: points(11) = 0
    points(12) = 4: points(13) = 4: points(14) = 0
    Set plineObj = ThisDrawing.ModelSpace.AddPolyline(points)
    ZoomAll
End Sub
GMT+8, 2026-1-17 04:44 , Processed in 0.168106 second(s), 24 queries , Gzip On.
