楼主: 120120
提供DCL源码文件.求帮编对应的LSP!
发表于 2007-8-15 20:49:00 | 显示全部楼层
可以。用LISP写一个DCL文件就行。
 楼主| 发表于 2007-8-16 08:57:00 | 显示全部楼层
晕!没人帮忙
 楼主| 发表于 2007-8-18 10:34:00 | 显示全部楼层
大家帮忙一下。。小弟在这里谢了!
发表于 2007-8-18 14:03:00 | 显示全部楼层
(defun c:cl()
  (YH_getdata)
  (setq YH_dclid (load_dialog "aa.dcl"))
  (new_dialog "aa" YH_dclid)
  (if YH_clb
      (setq YH_times (length YH_clb)
     YH_index 0
      (start_list "pmlist" 3 0)
      (repeat YH_times
 (add_list (nth YH_index YH_clb))
 (setq YH_index (1+ YH_index))
      (end_list)
      (end_list)
  (action_tile "pmlist" "(YH_showdata (atoi $value))")
  (setq YH_dcldone (start_dialog))
  (unload_dialog YH_dclid)
(defun YH_showdata (n)
  (setq YH_djbzl (nth n YH_jbzl)
        YH_index 0
  (repeat (length YH_djbzl)
    (set_tile (strcat "txt" (itoa (+ YH_index 1))) (nth YH_index YH_djbzl))
   (setq YH_dtz (nth n YH_tz)
        YH_index 0
(defun YH_getdata ()
  (setq YH_clb '()
 YH_jbzl '()
 YH_jbzl1 '()
 YH_tz '()
 YH_tz1 '()
 YH_rcl '()
 YH_rcl1 '()
 YH_yt '()
 YH_yt1 '()
   (setq YH_fileid (open (findfile "cl.txt") "r"))
   (while (setq YH_data (read-line YH_fileid))
     (if (DISTOF YH_data) (setq YH_clb (cons YH_data YH_clb))
  (if (= YH_data "基本资料:")
      (while (and (/= (setq YH_data (read-line YH_fileid)) "特性:") YH_data)
        (setq YH_jbzl1 (cons YH_data YH_jbzl1))
      (setq YH_jbzl (cons (reverse YH_jbzl1) YH_jbzl)
     YH_jbzl1 '()
  (if (= YH_data "特性:")
      (while (and (/= (setq YH_data (read-line YH_fileid)) "热 处 理:") YH_data)
        (setq YH_tz1 (cons YH_data YH_tz1))
      (setq YH_tz (cons (reverse YH_tz1) YH_tz)
     YH_tz1 '()
  (if (= YH_data "热 处 理:")
      (while (and (/= (setq YH_data (read-line YH_fileid)) "用途:") YH_data)
        (setq YH_rcl1 (cons YH_data YH_rcl1))
      (setq YH_rcl (cons (reverse YH_rcl1) YH_rcl)
     YH_rcl1 '()
  (if (= YH_data "用途:")
      (while (and (/= (setq YH_data (read-line YH_fileid)) "") YH_data)
        (setq YH_yt1 (cons YH_data YH_yt1))
      (setq YH_yt (cons (reverse YH_yt1) YH_yt)
     YH_yt1 '()
  (setq YH_clb (reverse YH_clb))
  (setq YH_jbzl (reverse YH_jbzl))
  (setq YH_tz (reverse YH_tz))
  (setq YH_rcl (reverse YH_rcl))
  (setq YH_yt (reverse YH_yt))
发表于 2007-8-18 14:04:00 | 显示全部楼层
没写完,要收工回家了,剩下的自己照猫画虎完善吧
发表于 2007-8-18 15:40:00 | 显示全部楼层
数据:注意每项内容后要加空行,最后要加两个空行。
  1. 168
  2. 基本资料:
  3.           名称:168
  4.           类型:--
  5.           生产商:瑞典一胜百(ASSAB)
  6.           出厂状态:淬火回火-340HB
  7.           C碳 Si硅 Mn锰 Cr铬 S硫
  8.           0.33 0.35 1.35 16.7 0.12
  9. 特性:
  10.           1、优良的耐腐蚀性;
  11.           2、优良的抗压强度;
  12.           3、任何尺寸,硬度分布平均;
  13.           4、优良的机械加工性。
  14. 热 处 理:
  15.           软性退火:在保护状态下,加热到860℃,然后在炉中以每小时20℃的速度,冷却至650℃,然后再放空气中冷却。
  16.           消除应力:以经粗加工后,必须加热至最高550℃,保温2小时,然后于空气中冷却。
  17.           淬火:注意:模具应确保在淬前以充分退火 预热温度:500℃ -600℃,淬硬温度:1000℃-1030℃,当模具中心和表面温度一同达到淬火温度后,保温30分钟。淬硬时必须保护,以避免脱碳及氧化
  18. 用途:
  19.            1、塑胶模模座、垫板,168配合S316模具和ELMAX镶块可成为完美的不锈钢模胚;
  20.            2、抛光性要求不高塑胶和橡胶模;
  21.            3、塑胶挤压模;
  22.            4、结构零件。
  23. 2083
  24. 基本资料:
  25.           名称:2083
  26.           类型:--
  27.           生产商:德国撒斯特(SAARSTAHL)
  28.           出厂状态:HB:215~240
  29.           C碳 Si硅 Mn锰 Cr铬 Mo钼 V钒 NI镍 W钨
  30.           0.43   -  13.0  0.3  -    -   0.5  -
  31. 特性:
  32.           抛光后可达超级镜面,并且有优良的搞腐蚀性。
  33. 热 处 理:
  34.           --
  35. 用途:
  36.            可用于制作生产批量较大,模具尺寸较大,尺寸精度、表面抛光性能要求较高的高质量塑料成型模具等。
复制代码
程序:
  1. (DEFUN C:AA ()
  2. (IF (SETQ NM (FINDFILE "AA.TXT")) (PROGN
  3.   (SETQ CLB (LIST))
  4.   (SETQ F (OPEN NM "r"))
  5.   (SETQ LAB (LIST "基本资料:" "特性:" "热 处 理:" "用途:")
  6. BLB (LIST "JBZL" "TX" "RCL" "YT"))
  7.   (WHILE (SETQ CLM (READ-LINE F))
  8.    (SETQ CLB (APPEND CLB (LIST CLM))
  9.   I -1)
  10.    (READ-LINE F)
  11.    (REPEAT 4
  12.     (READ-LINE F)
  13.     (SETQ BLM (READ (STRCAT (NTH (SETQ I (1+ I)) BLB) CLM)))
  14.     (SET BLM (LIST))
  15.     (WHILE (/= (SETQ L (READ-LINE F)) "")
  16.      (SET BLM (APPEND (EVAL BLM) (LIST L))))
  17.    )
  18.   )
  19.   (CLOSE F)
  20.   (IF (> (SETQ DCL_ID (LOAD_DIALOG "AA")) 0) (PROGN
  21.    (IF (NEW_DIALOG "aa" DCL_ID "") (PROGN
  22.     (START_LIST "pmlist") (MAPCAR 'ADD_LIST CLB) (END_LIST)
  23.     (SHOWTAB 0)
  24.     (action_tile "pmlist" "(SHOWTAB (ATOI $VALUE))")
  25.     (START_DIALOG)
  26.    )
  27.     (ALERT "Unable to display dialog box!\n无法显示对话框!")
  28.    )
  29.    (UNLOAD_DIALOG DCL_ID)
  30.   )
  31.    (ALERT "Unable to load dialog box!\n无法装载对话框!")
  32.   )
  33. ))
  34. (PRINC)
  35. )
  36. (DEFUN SHOWTAB (NN)
  37. (SETQ BLM (READ (STRCAT (CAR BLB) (NTH NN CLB)))
  38.        I -1)
  39. (REPEAT (LENGTH (EVAL BLM))
  40.   (SET_TILE (STRCAT "txt" (ITOA (+ I 2))) (NTH (SETQ I (1+ I)) (EVAL BLM)))
  41. )
  42. (SETQ BLM (READ (STRCAT (CADR BLB) (NTH NN CLB)))
  43.        I 0
  44.        NR (CAR (EVAL BLM)))
  45. (REPEAT (1- (LENGTH (EVAL BLM)))
  46.   (SETQ NR (STRCAT NR "\n" (NTH (SETQ I (1+ I)) (EVAL BLM))))
  47. )
  48. (SET_TILE "txt10" NR)
  49. (SETQ BLM (READ (STRCAT (CADDR BLB) (NTH NN CLB)))
  50.        I 0
  51.        NR (CAR (EVAL BLM)))
  52. (REPEAT (1- (LENGTH (EVAL BLM)))
  53.   (SETQ NR (STRCAT NR "\n" (NTH (SETQ I (1+ I)) (EVAL BLM))))
  54. )
  55. (SET_TILE "txt9" NR)
  56. (SETQ BLM (READ (STRCAT (LAST BLB) (NTH NN CLB)))
  57.        I 0
  58.        NR (CAR (EVAL BLM)))
  59. (REPEAT (1- (LENGTH (EVAL BLM)))
  60.   (SETQ NR (STRCAT NR "\n" (NTH (SETQ I (1+ I)) (EVAL BLM))))
  61. )
  62. (SET_TILE "txt11" NR)
  63. )
复制代码
 楼主| 发表于 2007-8-18 17:31:00 | 显示全部楼层
能不能不要TXT文件?把这个资料直接写在LSP文件里头?
发表于 2007-8-18 18:13:00 | 显示全部楼层
当然可以,但程序的可扩展性能差。
 楼主| 发表于 2007-8-18 18:27:00 | 显示全部楼层
ZZXXQQ,举个例子行不?
发表于 2007-8-18 18:41:00 | 显示全部楼层
师傅领进门,修行在个人.
GMT+8, 2025-12-17 23:44 , Processed in 0.194799 second(s), 19 queries , Gzip On.
