楼主: owenshowtime
关于vb和vlisp的问题
 楼主| 发表于 2007-9-6 08:31:00 | 显示全部楼层
自己顶一下,请各位高手帮忙看一下,curve.cls类模块的应用怎么做呢?最好能给个例子看看,谢谢!
发表于 2007-9-6 21:10:00 | 显示全部楼层
用上面两个
Option Explicit
Sub GetSplineMidPt()
Dim Cv As Curve
Dim objEnt As AcadEntity
Dim pickedPnt As Variant
Dim MidPnt As Variant
On Error Resume Next
Retry:
  ThisDrawing.Utility.GetEntity objEnt, pickedPnt, "Select a Spline:"
  If Err <> 0 Then
    Err.Clear
    MsgBox "You missed it."
  Else
    Set Cv = New Curve
    Set Cv.Entity = objEnt
    MidPnt = Cv.GetPointAtDistance(Cv.length / 2#)
    MsgBox "中点坐标 : " & MidPnt(0) & " , " & MidPnt(1) & " , " & MidPnt(2), , "Curve.cls Example"
    Exit Sub
  End If
  GoTo Retry
End Sub
发表于 2007-9-7 07:54:00 | 显示全部楼层
不如用vb把數據寫到*.txt文件,然後用lisp去讀文件
 楼主| 发表于 2007-9-7 08:31:00 | 显示全部楼层
多谢alin斑竹,以及各位大侠,小弟好像有点懂了,我再捉摸捉摸!再次感谢各位!
GMT+8, 2025-12-17 21:53 , Processed in 0.205301 second(s), 19 queries , Gzip On.
