查看: 1713|回复: 0
关于网络打印机的问题
发表于 2007-9-27 09:46:00 | 显示全部楼层 |阅读模式
最近我用VBA设计了一个批打印程序,遇到了一个问题:我使用的是局域网的打印机,其它的设置如打印机选择、打印方向、打印比表等都已经设计好了,并运行正确。但是,我不知道怎样选择网络打印机的纸张。在所有的纸张列表中就只有CAD默认的纸张列表(没有A3和A4),选择不了网络打印机的纸张列表,程序如下,请高手指点一下,怎样选择网络打印机的纸张。
Private Sub cmdCancel_Click()
    End
End Sub
Private Sub cmdDelete_Click()
    '确认列表框包含列表项
    If lstFile.ListCount >= 1 Then
        '如果没有选中的内容,用上一次的列表项。
        If lstFile.ListIndex = -1 Then
            MsgBox "请选择列表中的图形名称!"
            Exit Sub
        End If
        lstFile.RemoveItem (lstFile.ListIndex)
    End If
End Sub
Private Sub cmdOk_Click()
   Dim i As Integer
   Dim ii As Integer
   Dim zz As Integer
   Dim drn As String
   Dim drn1 As String
If lstFile.ListCount = 0 Then
MsgBox "请添加所要操作的图形!"
Exit Sub
End If
 If ComboBox1.Text = "" Then
          End If
           Select Case (ComboBox1.Text)
           Case Is = "HP-0"
           AAPRINTER = "\\Plotter3\hp-0"
            Case Is = "HP-1"
           AAPRINTER = "\\Plotter3\hp-1"
            Case Is = "HP-3"
           AAPRINTER = "\\Plotter3\hp-3"
            Case Is = "HP-4"
           AAPRINTER = "\\Plotter4\hp-4"
           End Select
drn2 = TextBox2.Text
zz = 1
   For ii = 1 To Len(drn2)
   ii = InStr(zz, drn2, Chr(92))
   If ii = 0 Then Exit For
      zz = ii + 1
   Next ii
   drn = Mid(drn2, zz)
frmMain.hide
For i = 0 To lstFile.ListCount - 1
drn1 = lstFile.List(i)
Application.Documents.Open drn1
ThisDrawing.ActiveLayout.RefreshPlotDeviceInfo
       Dim currentPlot As AcadPlot
    Set currentPlot = ThisDrawing.Plot
      ThisDrawing.ActiveLayout.PlotType = acExtents
        ThisDrawing.ActiveLayout.StandardScale = acScaleToFit
           ThisDrawing.ActiveLayout.StyleSheet = drn
           ThisDrawing.ActiveLayout.PlotRotation = ac90degrees
          ThisDrawing.ActiveLayout.CanonicalMediaName = ComboBox2.Text
          currentPlot.PlotToDevice AAPRINTER
          Application.ActiveDocument.Close False, drn1
Next i
End Sub
Private Sub cmdOpen_Click()
    On Error GoTo errHandle
    Dim i As Integer
    Dim Y As Integer
    Dim z As Integer
    Dim FileNames() As String
    With comDlg
        .CancelError = True
        .MaxFileSize = 32767
        .Flags = cdlOFNHideReadOnly Or cdlOFNAllowMultiselect Or cdlOFNExplorer Or cdlOFNNoDereferenceLinks
        .DialogTitle = "选择图形文件"
        .filter = "图形文件(*.dwg)|*.dwg|所有文件(*.*)|*.*"
        .FileName = ""
        .ShowOpen
    End With
    comDlg.FileName = comDlg.FileName & Chr(0)  '这些文件名是用空字符Chr(0)分隔符,而不是空格分隔符隔开
    z = 1
    For i = 1 To Len(comDlg.FileName)
        'InStr函数,返回 Variant (Long),指定一字符串在另一字符串中最先出现的位置。
        '语法 InStr(起点位置, string1, string2)
        i = InStr(z, comDlg.FileName, Chr(0))
        If i = 0 Then Exit For
        ReDim Preserve FileNames(Y)
        'Mid函数,返回 Variant (String),其中包含字符串中指定数量的字符。
        '语法 Mid(string, start[, length])
        FileNames(Y) = Mid(comDlg.FileName, z, i - z)
        z = i + 1
        Y = Y + 1
    Next i
    '向列表框中添加对象
    Dim count As Integer
    count = lstFile.ListCount
    If Y = 1 Then
        lstFile.AddItem FileNames(count), 0
    Else
        For i = 1 To Y - 1
            FileNames(i) = FileNames(0) & "\" & FileNames(i)
            lstFile.AddItem FileNames(i), i - 1 + count
        Next i
    End If
errHandle:
End Sub
Private Sub CommandButton2_Click()
    Dim i As Integer
    Dim Y As Integer
    Dim z As Integer
    With comDlg
        .CancelError = True
        .DialogTitle = "选择CTB文件"
        .filter = "数据文件(*.ctb)|*.ctb|所有文件(*.*)|*.*"
        .FileName = ""
        .ShowOpen
    End With
   TextBox2.Text = comDlg.FileName
errHandle:
End Sub
Private Sub UserForm_Initialize()
    lstFile.Clear
    ComboBox1.AddItem ("HP-0")
    ComboBox1.AddItem ("HP-1")
    ComboBox1.AddItem ("HP-3")
    ComboBox1.AddItem ("HP-4")
    ComboBox2.AddItem ("A3")
    ComboBox2.AddItem ("A4")
      End Sub
GMT+8, 2026-1-18 04:38 , Processed in 0.326851 second(s), 23 queries , Gzip On.
